1 - 2 of 2 Posts
Hey I am new to the aem ems, but I got my car to idle pretty good 14.5-15.3ish afr's. The car doesn't want to start when it is completely cold. Once its warmed up it starts right up. Do you guys think it is ok to drive (no boost) with what I currently have? When I rev it in neutral what should my afr's be? While crusing what afr's do I want to aim for? This is only a temporary map just so I can get my car from point a to point b then I am switching over to e85. Here are my mods that matter for tuning purposes and my current .cal file:
MpX BFMIC
3" dp
3" MpX SEE
AEM uego wideband
180° thermostat
BS chain removed
AGP Zeta 3.2 DBB turbo kit
N2MB boost & wot boxes
Performanceautowerks 2.5" hot side IC pipe
Full Blown fuel rail
-10 feed
-8 return
Aeromotive A1000 fpr
DCR Twin Bosch 044 in-tank pump unit
DCR 8 gauge fuel pump rewire
Duster's 1025cc injectors (rated at 58psi)
Magnecore 8mm wires
NGK 4306 plugs
AGP 3bar map/tip sensors
Thanks.
Im not too familiar with EMS on an SRT4, but your idle target afr's seem solid. just make sure you stay out of partial throttle boost and of course WOT. nothing will happen i can assure you. ive had customers that drove on base maps for prolonged periods of time, as their cars were their daily drivers, on setups that have not been tuned. just keep your eye on your afr's and check your LT knock once in a while, just to be safe. cruise and light acceleration should be in the 14's (low 15's at idle).
1 - 2 of 2 Posts
