I Currently have an e-manage / e-01 combo controlling my 750cc injectors and fuel pump. I do not have a fuel pressure regulator and return line setup and I am trying to get my car to idle correctly.
It is an 04 with a Stage 1 pcm in it (although I would like to swap in my stock PCM if possible)
I have the e-manage setup with 450 as the starting injector size and 750 as the new one. It comes up with a correction rate of .600.
I have tried taking out 5 to 10 percent more fuel at idle using the airflow adjustment map but it doesnt seem to help. I know the emanage is working because I can feel a slight shudder when I make the changes but the idle is still very lumpy ( like it is missing or has a very agressive set of cams in it.)
Now, if I blip the throttle a little, it will settle down. It doesnt take long for it to go back to the rough idle though.
Does anyone have any insight on this?
Thanks!
Thanks!
