I have been working for a while on this map and it is getting much better. You will notice I have a huge bump at 2800rpm in fuel, and for some reason that is just needed to keep the car from stumbling and maintaining a good afr.
I am not a pro tuner and most of this has been done just casually, so if you have any tips or thoughts on things I could change... I would be more than happy to listen and hopefully learn a thing or two.
EDIT: I did do some changes to the 0-10% tps signal cause I had issues coming off idle, or taking off from a stop light. Does everything look normal?
-Garrett
-Garrett
