Just wanted info.
460 to the wheels a good driver, bfg dr,solid mounts ect....
What would be a good time it should run at the track?
1/4 mile times not 1/8
Also anyone use a 2 step on their srt for launches if so what rpm?
thanks,
Mike
11s if you can hook it somewhat. Too much power for a Drag radial probably need a slick
If you can get that 2-step worked out correctly I think you could hit an 11. It will be hard with the DR's though...obviously are cars don't have a problem flying once they're moving, so our times are all in our 60'
ok with slicks looks like 11.s but high or low.
Is that enough power to be knocking on the door of the high 10.s?
Thanks
You can check the fastest timeslip list and get a good idea of what people are running with your power levels. That will give you a general idea of what is possible.
