1 - 9 of 9 Posts
All,
Has anyone ran this M&H setup?
Is a spacer needed and what size do you use to clear the perch.
Or will a cutting wheel/die grinder be needed?
Thanks,
Marion
I used ptsteelies and 24.5/8.5/15 slicks on stock struts no problem. I had a local guy asking me if he could do it also cause M&H told him only a 26x6 would fit. I belive dasmopar ran the same tires differnt wheels on his car with stock struts.
With a 1" drop from the Mopar Springs included?
Marion
mario03srt said:
All,
Thanks,
Marion
I have the same setup. Fits fine! no spacers needed
Discussion Starter #7
Thanks for the replies. 1.7 60ft here I come.
Marion
Marion
Come on Marion. I think the med's are working your brain over. The springs won't change the location of the spring perch in relationship to the wheel hub. They will fit. If anything you may need a 1/8" wheel spacer. But not because of the spring perch. The slick is so wide that it will rub on the strut body while turning just a touch without a spacer.
Discussion Starter #9
Das,
For some reason I was thinking the spring height had an effect on the perch to control arm distance. So when a shorter spring was installed that distance shortened too.
BTW the Vicatin has been gone for a few days.
I hope things are well with Das Senior.
Marion
1 - 9 of 9 Posts
