1 - 20 of 52 Posts
Discussion Starter #7
srtfoyoazz do you have some close up pictures of your rims and tires you could post or send me?
A 235 on a 7 inch wide rim is not a good idea, sure it can work but certainly not recommended!
I run a 235 on a 7.5 wide rim and even that is pushing it (should be 8) however I have no bulging on the sides like in the picture above.
Administrator
yeah, because of the taller sidewall. the shorter the sidewall, the wider the wheel must be for a given width of tire.
slcsilversrt-4 said:
im gonna run a 235/60-15 on a 7 inch wide.
though the tire specs indicated 6.5 to 8.5 will be ok.
are you talking about dr's? i run m&h's those size on a rota wheel only 6.5 with no prob :readclose
1 - 20 of 52 Posts
