2004 E-Blue. Runs but needs work. Idle is messed up and needs exhaust welded up (has straight down pipe), needs battery, needs tune.
mods are listed below. mileage is 204,000.
contact me at text only if your serious 205-412-522zero
ENGINE AND PERFORMANCE MODS:
MOPAR STAGE 3 W/TOYS
PORT N POLISH TURBO
TURBO REBUILT AND INTERNALS ARE AS FOLLOWS:
TBP CUSTOM GTX PROFILE BILLETNCOMPRESSOR WHEEL 73MM
TBP UPGRADED 18MM THRUST KIT
DUAL OIL FEED
LARGER PADS
NEW BEARINGS
NEW SEALS
NEW PISTON RINGS
HONED BEARING HOUSING
TBP 9 BLADE HIGH FLOW TURBINE WHEEL (EXTENDED HEIGHT)
ULTRASONIC CLEANED INTERNALS AND COMPUTER BALANCED ASSEMBLY
PORT N POLISH EXHAUST MANIFOLD
MPX STAGE 3 O2 HOUSING 3.5IN TO 3IN
EXHAUST MANIFOLD-CERAMIC COATING IN/OUT
HKS BLOW OFF VALVE SSQV
DCR OIL PUMP
DCR OIL PICK UP TUBE
DCR BIG OIL FILTER KIT
DCR WINDAGE TRAY
AEM SRI
QUICK WHIPS BFMIC
SLOWBOY RACING CRASH BAR
TORQUE SOLUTIONS PHANTOM BLACK ENGINE/TRANS MOUNTS
255LPH FUEL PUMP
FUEL PUMP RE-WIRE KIT
AGP FUEL RETURN KIT
GUTTED FPR AND AP FUEL PRESSURE REGULATOR UNDER HOOD WITH GAUGE
RED LINE TUNING HOOD STRUTS
180 DEGREE THERMOSTAT
MPX CATCH CAN
P-WERKS GROUNDING KIT
3” E.D. TURBO-BACK EXHAUST W/ MAGNAFLOW CROSSFLOW MUFFLER
HP TUNERS MPVI 2
N2MB WOT BOX W/ 2 STEP
BOOGER BLUE SHIFTER BUSHINGS
TURBONECTICS COLD SIDE PIPE
DCR OIL MOD
SUMMIT RACING BATTERY RELOCATION KIT
INTERIOR MODS
TRIPLE GAUGE POD
MOPAR 30PSI BOOST GAUGE
MOPAR VOLT GAUGE
MOPAR AFR GAUGE
AEM AFR GAUGE
MOPAR OIL PRESSURE GAUGE
MOPAR GREY SHIFT KNOB
MOPAR SHORT THROW SHIFTER
MOPAR TRUNK CARPET
BLACK RADIO BEZEL
PIONEER HEADUNIT
PIONEER 6 DISC CHANGER
KICKER LIVIN’ LOUD SYSTEM (EXCLUDING CD CHANGER)
DODGE CHROME DOOR STILL COVERS
EXTERIOR MODS
SMOKED LED TAILLIGHTS
SMOKED CORNERS
WINDOW TINT
SRT NOSTRIL BADGE
OEM STYLE BLACK HOUSING HEADLIGHTS
SMOKED FOG LIGHTS
STAGE 3 BADGE
SUSPENSION MODS
PT CRUISER 26MM FRONT SWAY BAR
ACR 19MM REAR SWAY BAR
MOPAR TENSION STRUTS
MOPAR STAGE 1 LOWERING SPRINGS
MOPAR FRONT AND REAR STRUT BARS
Motor vehicle Vehicle Hood Light Car
Automotive parking light Grille Automotive lighting Automotive tire Hood
Land vehicle Automotive lighting Automotive tire Speedometer Motor vehicle
Motor vehicle Speedometer Odometer Automotive lighting Gauge
Vehicle Land vehicle Speedometer Car Trip computer
Car Vehicle Motor vehicle Steering wheel Automotive design
Car Vehicle Land vehicle Vehicle registration plate Automotive lighting
Wheel Tire Car Vehicle Window
Car Vehicle Grille Vehicle registration plate Hood
