I guess I shouldn't complain, there are no codes going off and it has been going for 300 miles since I put in S1 and leak tested, but the last 2 days I have been driving with occasional romps up to 10 psi at most as needed. Babying the car. Today in 5th at 75, floored it pegs the needle(20+) and falls to 17-18 and has a bit of shudder. Tried 4th at 65 and same thing boost hits 20+ then goes to 17-18 with a touch of shudder and stays there as long as I keep on it. Is this the timing? Or too much gap?
NGK 4306's at 0.045, do I need to shrink that gap? 0.040?
Gap them to 35 but thats really not the problem. its the wga. Its going to do the same thing no matter what you do. I have stage 2 and a bc and i spike 22-23 (in know there no point just hot air at that point but thats why i hold 20 till 5800) and i still fall back to 15-18 depending on what gear im in. In fourth and fifth it hold 19-20 untill almost redline then it drops.
So leave it and deal with it....that is the verdict?
I can do that, if that is what you are saying.
Will adjust the plugs though...
Yup thats what im saying and probally anybody thats going to read this thread. :)
Okay using Blackbird's suggestion, I lowered the gap to .037 and the bump sensation is 90% gone now. I am happy with the way it is. I did order a set of Champion 570's today and will tamper with them later.....
Just a question, do you have a wideband of any sorts?
What do you think your timing is doing?:eeeek:
