So I recently picked up an 04 srt4 she is a great running car besides a tick at under 3000rpms in every gear and I cannot seem to get into first gear I was told by the nearest performance shop to check my shifter bearings but I have had multiple responses on what it could be could someone help me out!
yep, check shifter cable bushings (at the shifter and on top of the transmission). try adjusting the clutch pedal out some (there is an adjustment on the pedal) to give a little more throw on the throw out bearing. report back.
Hopefully it is not your clutch fork. The clutch pedal adjustment will buy you some time. The fork is a known problem with these cars. You dont want to drive it too long with a bad fork. It will destroy your synchros.
i've not heard of the 1-2 gear fork being a known issue. The 3-4 fork is.
