I have a LSD out of an 04 SRT-4, I will just need the install kit and it will work in my 03 tranny right?
Thanks for any info.
Ben
Ben
You should not need the install kit, as you are not taking off the ring gear, unless you want fresh bearings and races. You will need a large assorment of the shims for adjusting it if it's a self install though.Honda Hunter said:I think that the tranny has 3K on it.
Yes it needs to be measured and the appropriate shim installed. The great thing about the T-850 is no need to remove the tranny! But find an experienced shop as it's worth the money of not having the aggrevation.Honda Hunter said:Do shims come with the install kit?
The only thing that I am not sure about is the shims. If it was just a matter of opening up the tranny and swapping in the new diff, I would do it myself. If it has to be measured and shimmed, I guess I will take the tranny out, and take it to a tranny shop.
The Phantom Grip install on my neon was pretty easy, figure this is about the same.
BEn
my quaife was installed without removing the tranny......I have put almost 10,000 miles on it since it was installed. No problems here! Works perfect! :thumbsup:Honda Hunter said:So, that means that I do have to take the tranny out and disassenble it totally to adjust it correctly. That sucks.
Sound like everyone that has installed the quaife with the tranny in the car has done it wrong?
ryansrt said:my quaife was installed without removing the tranny......I have put almost 10,000 miles on it since it was installed. No problems here! Works perfect! :thumbsup:
