My 2004 is about to go up on the rack for an engine build, as well as a little transmission and suspension work. I bought it 6 years ago with 35K on it, and put another 54k on it as a daily driver.
I put an SRI, direct fit FMIC, and a 3" turboback exhaust on it right away, but I never even went WOT in 5 years. In December 2013 I suddenly decided to take up drag racing, and it's been a very expensive hobby, as you well know.
I'm 35 years too old for this, but I can't stop modding.
I'm buying everything in sight, and I pore over the Modern Perf site trying to find something I haven't bought already.
The money hasn't paid off yet;my best time in 2013 was [email protected], even with a BWS and 380 HP according to the Mustang dyno..
It's time to install all the stuff I bought, and more's arriving every day. Somebody stop me!
2009 mods:
Weapon R SRI
Exhaust Depot FMIC direct fit
Exhaust Depot 3" turboback
2014:
15GK2 BWS from MIC
FM wastegate
AGP engine, trans mounts
Intune
888cc injectors and Needless Torque tune (usually the E85 tune)
AGP fuel return
BC coilovers
PT Cruiser steel wheels
M&H 235/15 Street and Strip
ARP extended wheel studs
NGK NTK wideband
MPx catch can (leaks!):flame:
new hoses
new belts, except timing
new vacuum solenoid
HKS blowoff valve
SDK race port exhaust manifold
JMB ported intake
MPx 62mm throttle body
new battery
new PCV
JMB upper pressure pipe
AGP lower pressure pipe
Walbro 255 and rewire kit
Granatelli coil
MSD wires
NGK iridium plugs 0.039" gap
Scangauge
ACT HDSS clutch (burned up soon after I installed the BWS;found out what that burning smell was on the dyno and at the track;too much torque!)
ACT HD 6-puck replaced the street clutch
Yokohama Advan Neova 008 tires for the street
Hurst shifter
Ragetek clutch pivot arm
Mopar clutch fork and throwout bearing
Clutch pivot ball
Radiator cap, high pressure
N2MB WOTbox with 2-step
DSS Level 3 axles
2015:
AGP shift extenders
Raptor shift light
Energy suspension bushings
Blockoff plate for stock blowoff valve
180 deg thermostat
ARP head studs
Head ported locally
MPx cam gears
Crower S1 cams
OEM timing belt
Mopar water pump
Mopar tensioner
Mopar oil pump
Mopar idler bearing
DCR direct fit strap kit
DCR windage tray after balance shaft removal
DCR stock bore pistons
Manley rods
Mopar rod bearings
Mopar main bearings
Mopar main seals
Mopar cam seals
Mopar valve seals and spark plug seals
Mopar bottom end gaskets
DCR head gasket
Mopar exhaust gasket
Hondata intake gasket
Mopar spark plug seals
BC 1mm oversize valves and keepers
BC valve guides
Crower titanium retainers and springs
PWerks bottleneck kit
Mopar 2.7L rockers
PT Cruiser lash adjusters
New E85 and gas tunes
Did I miss anything?
I'm about to purchase a DCR treated input shaft, but I may not install it until after this race season. I might do a full transmission rebuild at the same time. I might add a carbon fiber trunk to lose some weight, and the red paint looks like it's got a bad case of leprosy.
I'm thinking about Enkei light racing wheels for the back. I'm also thinking about Bogart wheels in the back with 3.6" skinnies for track days, but the guys in the street legal group at Atlanta Dragway Fast Fridays would look askance at me.
I even spent $300 for 30 gal of VP C85. I'm running out of stuff to buy; maybe a bigger turbo...nitrous? This build should be able to handle most anything;might need a bigger pump and fuel lines for 500 hp in the future.
Right now the goal's a very reliable 400 whp. I have to drive it 2 hours to the track, so reliability is paramount.
2009 mods:
Weapon R SRI
2014:
15GK2 BWS from MIC
FM wastegate
Intune
AGP fuel return
BC coilovers
NGK NTK wideband
new hoses
new vacuum solenoid
HKS blowoff valve
JMB ported intake
new battery
new PCV
Granatelli coil
MSD wires
Scangauge
Hurst shifter
Clutch pivot ball
DSS Level 3 axles
2015:
AGP shift extenders
Raptor shift light
180 deg thermostat
ARP head studs
Head ported locally
MPx cam gears
Crower S1 cams
OEM timing belt
Mopar water pump
Mopar tensioner
Mopar oil pump
Mopar idler bearing
Manley rods
Mopar rod bearings
Mopar main bearings
Mopar main seals
Mopar cam seals
DCR head gasket
BC valve guides
Mopar 2.7L rockers
