1 - 20 of 20 Posts
I hooked up my returnline and the gauge read 0, so i bought a nicer liquid cooled one and still at 0...found out it was because my fuel rail had a schrader valve and that was the bitch locking the fuel in. So i broke it off with some nose pliers...(dont know if i should have done that) but now my gauge works at its set at 55ish. So my question is should i have broken the schrader valve? can i run into any problems?
did you get the whole thing out? It's just like a valve stem...a straight blade jeweler's screwdriver would have taken it right out the correct way
how long is it supposed to be?
but only the pin was supposed to come out right
i took mine out, then used a drill bit & drilled the whole thing out so there isn't a "bottleneck" in it ... not that it would really make a difference
Hey, ill take a look at next time I see you. From what you told me via IM you should be fine for now. I have a valve core remover in my box
~edit~ typing>me
Discussion Starter · #11 ·
ImportLabSRT4 said:
Hey, ill take a look at next time I see you. From what you told me via IM you should be fine for now. I have a vlave core removed in my box
u da man
On topic, where can I get the actually schrader valve? I am running a S3 rail with a fuel pressure sensor on the end of it..Well I mis-placed the schrader valve and need to know where I can get one that will work since I am planning on taking the sensor off.
It looks just like a valve used in a tire valve stem, I think it maybe the same thing.
It is a standard AC schrader valve.... just get one thats for AC systems and not tires.
Awesome, thanks a ton! :) Little worried it was something special.
Doing a engine swap to a eclipse. On the 03 rail can I block of the inlet and use the vavle inlet as a fuel inlet. Remove the valve and drill it out.?
I wouldn't think it was big enough. I dink know how much fuel you need but there's not a whole lot of ID inside the threaded side. Also it's not a AN style fitting so you would have to find the addapters.
And yes i know the inlet side isn't overly large either.
/\. Do this
1 - 20 of 20 Posts
