Project "To be determined" - Time Attack Car - Dodge SRT Forum
 2Likes
post #1 of 22 (permalink) Old 06-24-2019, 02:48 PM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
Drove a total of 10 hours outside of Toronto in the middle of nowhere to pickup this barn find. 115,000km on the odometer, faded paint but little to no rust! Going to transform this into a track car and compete in time attack within the next year!
Mods it came with:
-Mopar strut braces
-AGP front mount
-Mopar cold air intake
-Hurst short throw shifter
Personal Track Time Records:
Toronto Motorsports Park:
03/07/2019 - 01:26:30
Initial pickup photos:
HybridKid likes this.
thaid is offline
post #2 of 22 (permalink) Old 06-24-2019, 04:01 PM
JeremyJ's Avatar
Quoted: 13 Post(s)
Track racer FTW. I look forward to seeing some build progress with this one.
02 Base - 05 SRT ACR - 96 Sedan - 99 R/T - 02 R/T - 03 SRT
JeremyJ is offline
post #3 of 22 (permalink) Old 06-26-2019, 07:53 AM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
Initial inspection and mods
Went into my trusted performance shop for a shake down. Front calipers were on their way out. Bushings all around needed replacing. A few other minor parts like the tank strap was rusting to pieces. Gave the go ahead for the repairs and initial mods!
Dropped in BC coilovers
Replacement seats ready to go
Resorted to witchcraft and magic to get these tires on. 17x8 Konig Dekagrams ET40, Hankook RS4 245/40/17. Found the wheel bearing and studs were not in great condition also. So slapped in some ARP wheel studs on all 4 corners.
Stoptech 309 pads with Stoptech slotted rotors. Replaced the seized calipers with reman Powerstop from RockAuto.
Only managed to get 1.5 degrees of camber out of these coilovers due to everything hitting everything.. will have to research on how to get more camber out of these.
thaid is offline
post #4 of 22 (permalink) Old 06-26-2019, 08:47 AM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
you'll probably have to go with a lower offset wheel to get more clearance for more camber. I've run 255/40/17 on 17x8 with ET35 without clearance issues, but i also wasnt trying to run a lot of camber.
435 HP & 438 TQ -E85
Tuned by Turbo666 on his mustang dyno
Best ET to date: 12.1 @ 124 on DR's
gump1114 is offline
post #5 of 22 (permalink) Old 06-26-2019, 09:07 AM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
Thanks for the info! But with the wheel setup I went with, we didn't run into the traditional clearance issue. Its when we tried to crank more camber it would hit the strut assembly one way or another. We tried putting in camber bolts but same thing, the tire would catch somewhere and stop us. I'll be taking it for a shakedown at the track first to get used to this new chassis, and then look into dialing in more camber down the road.
thaid is offline
post #6 of 22 (permalink) Old 06-26-2019, 09:15 AM
dave gregory's Avatar
Quoted: 13 Post(s)
Nice car
1986 GLHS #329
2004 SRT4 Powered by DCR & Forward Motion
FM Stock Appearing Stage 5 Buildup (E1 Turbo, Factory cams/gears) Turn Key Ready
dave gregory is offline
post #7 of 22 (permalink) Old 06-26-2019, 10:01 AM
JeremyJ's Avatar
Quoted: 13 Post(s)
I'm running 17x8 et35 RPF1s with 235/40s on them. The tires would touch the coilovers unless I added a 3mm spacer. I don't know how you guys fit such wide tires on these things without major rubbing. I'm only running -1 camber on the BCs right now.
JeremyJ is offline
post #8 of 22 (permalink) Old 06-26-2019, 10:30 AM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
In the front, the upper bolt holes that the strut uses to attach to the knuckle are slotted. So you have some adjustment there, as well as at the top of the strut tower. I'm also on BCs.
gump1114 is offline
post #9 of 22 (permalink) Old 06-27-2019, 09:01 AM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
Do you know how much camber approx you're running? I'll take another look at those slotted holes.
thaid is offline
post #10 of 22 (permalink) Old 06-27-2019, 10:16 AM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
sorry i do not know off the top of my head. I just recently went through and replaced a bunch of parts in the front end, so it needs an alignment. I can update you once that is complete.
gump1114 is offline
post #11 of 22 (permalink) Old 06-27-2019, 03:52 PM
T4EaterJonny's Avatar
Quoted: 435 Post(s)
Garage
I ran -2.7 in the front and -2 in the back. 17x8 245's BFG Rivals. no spacers. Just rolled the fenders. Car is not slammed. 14'' in the back from centerline of axle to top of fender and 13.75 or something like that in the front. I think this is as low as an SRT should be. I've pretty much given up on trying to make this car handle well. The car is meant to be a 3rd and 4th gear pull car lol
s3*ps2 likes this.
Red 2005 Big wheel stage 3, E85, BC rods, JE pistons stock 8:1 .020 over, BS delete, Sways & STbraces, coilovers valved by Feal, diy NACHO solid control arms.
Yellow 2004 C5Z06
White1994 XR600R street legal! Have you driven an SRT-4?... Lately?
T4EaterJonny is offline
post #12 of 22 (permalink) Old 06-27-2019, 07:19 PM
Gizmodo's Avatar
Quoted: 100 Post(s)
I run -2.7 up front on 235/40/17 tires. My car is pretty low and I don't have problems with rubbing. I have stock control arms up front with Realtune bushings and modified struts with Ground Control camber plates.
Click image for larger version
Gizmodo is offline
post #13 of 22 (permalink) Old 06-28-2019, 06:36 AM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
Final touches
Thanks for the input guys! Good to see its possible to run more camber on a ~245 wide tire.
New update. Final touches added. CBD Carbon hood.. serial #001 (I think thats pretty cool lol) installed. Hit the mountain roads for some spirited driving with my squad for a quick shake down.
Close up:
Dropped in fresh oil. Amsoil Diesel DEO 5W40. My trusted oil for years on forced induction cars.
Foam washed art:
At the end of the day, everything looks good. Car is safe and ready to set a lap time at the track. I'll keep a lap time record on the main post so you guys can see the improvements i've done through the build.
thaid is offline
post #14 of 22 (permalink) Old 06-28-2019, 11:43 AM
JeremyJ's Avatar
Quoted: 13 Post(s)
I want to see pics of the seats installed.
JeremyJ is offline
post #15 of 22 (permalink) Old 07-03-2019, 07:48 AM Thread Starter
thaid's Avatar
Quoted: 1 Post(s)
Garage
I didn't get a chance to install the seats so they're still sitting in the garage. I'll post a picture when I have them installed.
Update! Went on a trackday with the boys at Toronto Motorsports Park. Managed a 1:26.3 (I will be keeping personal lap records on the main page so you guys can see my progress).
Ran into a couple of issues.. car caught fire at the exhaust tips. Tried to pry the exhuast down so it sits lower... haha.
Power steering fluid would overflow from the cap. Not sure if its boiling or just expanding, but it seems to be a common issue when you run these cars hard. If anyone has any suggestions/possible fixes, please chime in. I'll probably replace the cap and replace the fluid with Red Line power steering fluid to see if that'll fix the issue.
thaid is offline
« 97 Turbo Neon | -
User Tag List
Linear Mode Linear Mode
Similar Threads
Car Names Explained...add yours! LOL hemidakota General Car Discussion 5 08-03-2004 11:50 PM
The Gran Tourismo 4 Car list fierostetz SRT-4 Discussion 118 04-14-2004 12:31 AM
We started on the new Project car today! rezin8 SRT-4 Discussion 14 03-31-2004 02:06 PM
NORCAL MEET! Extreme Autofest Car Show, Sonoma CA, July 27th Avengeance Southwest 1 06-30-2003 07:37 PM
