97 Turbo Neon - Dodge SRT Forum
 59Likes
post #1 of 312 (permalink) Old 02-27-2012, 09:35 AM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
97 Turbo Neon
I have had this project done for some time. and I went through the intial build and then eventually another motor rebuild on it. and now it sits with a junk motor again.
But there are more plans in the stove for after deployment.
Old look with the N/A motor
This is the old motor 2.4L Stratus swap
97 Stratus Block with SRT internals and 05 SRT head
After motor completion
Installed
All Wired up
Inter-cooler Install
Still more pictures to come. but what do you guys think.
It was still running on the 97 Computer
1997neon is offline
post #2 of 312 (permalink) Old 02-28-2012, 11:28 AM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
Had a couple people look at the thread but no replies. so i will post more upgrades that i have done to the car
Out with the old and in with the new
Also pictures from same time as changing suspension and adding SRT rims
These next pictures are things that will be going into my car when i get back from deployment.
Another true SRT motor
A full SRT swap on electrical
And an upgraded turbo
97 Neon SRT swap
GTX3076r, AGP Log Manifold, AGP Big O2, Wally 255, return line system with Fuel Lab RRFPR, Eagle Rods, JE Pistons, ARP Head Studs, Crower Valve spring and retainers, 2.0 Exhaust Cam, Balancer Shaft Delete, DCR Crank Straps, DCR Windage Tray, DCR Modified Oil Pump, DCR Oil Pick-up, HKS SSQV, Exhasut Depot 3" SEE, 38mm Turbosmart WG, Stage 2/3 Injectors, 3 Bar MAP and TIP, MTX, Quife LSD, FX700 Clutch, DSS Level 5 Axles
1997neon is offline
post #3 of 312 (permalink) Old 02-28-2012, 10:04 PM
Isy
New Member
Isy's Avatar
Quoted: 0 Post(s)
Nice build, What turbo did you upgrade to
Silverbeast Precision SC6165R Crane 18's
ZHP Enhanced-03 Srt, 05 Block, 04 tranny
Down Again in the Driveway Again after 6 Yrs
[B]Going back to Stock, Breaking down in Process
Isy is offline
post #4 of 312 (permalink) Old 02-28-2012, 10:53 PM
greenneonsrt's Avatar
Quoted: 3 Post(s)
Awesome work man! I started buying parts to do the swap last year but ended up buying an srt instead.
I bet this thing pulls, I've seen quite a few srt swapped 1gns run 11s with just a bone stock srt motor and slicks.
greenneonsrt is offline
post #5 of 312 (permalink) Old 02-28-2012, 11:31 PM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
the turbo is a prototype. its called the S3k its the stock turbo with a 20g wheel inside of it.
yeah it is but i never got all the kinks out of it on the stock ECU
97 Neon SRT swap
1997neon is offline
post #6 of 312 (permalink) Old 02-29-2012, 04:49 AM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
Here is a video of the car running the day after i finished it.
A/F ratio was off cause it was running the stock 1g ECU, no FMU, and the Map sensor was broken.
Also turbo didn't surge/blow off correctly because i had so Vacuum lines hooked up wrong
1997ne0n's Channel - YouTube
97 Neon SRT swap
1997neon is offline
post #7 of 312 (permalink) Old 03-02-2012, 04:00 AM
edub20's Avatar
Quoted: 0 Post(s)
subscribed
Evan
2004 dodge srt-4 (stockish)
1997 dodge neon (srt swap)
edub20 is offline
post #8 of 312 (permalink) Old 03-02-2012, 04:06 AM
edub20's Avatar
Quoted: 0 Post(s)
whered you buy that turbo if you dont mind me asking?
Evan
edub20 is offline
post #9 of 312 (permalink) Old 03-02-2012, 06:36 AM
New Member
Quoted: 0 Post(s)
i was readign the s3k with the 20g compressor wheel had issues too small of a turbine? i know the 18g compressor and 16g versions worked fine tho
loroku is offline
post #10 of 312 (permalink) Old 03-02-2012, 01:53 PM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
the guy i bought it from said he had no problems with it but either way if i do end up having problems with it i have 5 stock SRT turbos sitting at my house that work fine. so i am sure i can sell them and always get a different one.
video of turbo in previous owners car. wish there was more video of it though.
97 Neon SRT swap
1997neon is offline
post #11 of 312 (permalink) Old 03-02-2012, 01:55 PM
edub20's Avatar
Quoted: 0 Post(s)
yeah i just seen on the org, where you bought it from.....you might wanna contact mole on here, he use to work for the guy that had them built
Evan
edub20 is offline
post #12 of 312 (permalink) Old 03-02-2012, 09:04 PM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
yeah mole contacted me on the org and warned me already
97 Neon SRT swap
1997neon is offline
post #13 of 312 (permalink) Old 03-03-2012, 04:43 AM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
been thinking about doing an SRT front end modification to the car as well but i am not to sure yet. i have all the parts minus the hood and headlights.
i know i don't have a coupe and its kinda point less but oh well.
have bumper and all other parts sitting at my house.
other wise if i get a good offer on the SRT front end i will sell it.
97 Neon SRT swap
1997neon is offline
post #14 of 312 (permalink) Old 03-16-2012, 01:21 PM Thread Starter
1997neon's Avatar
Quoted: 6 Post(s)
I will be back state side in about 45 days with boots in MN. Can't wait to get started on this thing.
Still open for offers on the SRT front end. everything is there except for the hood and the headlights.
97 Neon SRT swap
1997neon is offline
post #15 of 312 (permalink) Old 03-16-2012, 02:29 PM
the hyena's Avatar
Quoted: 0 Post(s)
Sexy ass swap!
Project BlueShift
the hyena is offline
User Tag List
Linear Mode Linear Mode
