PCM Boost By Gear - Page 8 - Dodge SRT Forum
 1Likes
post #106 of 116 (permalink) Old 01-05-2011, 09:50 AM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Originally Posted by Cheftank View Post
and already did solenoid delete
Solenoid delete is the worst srt mod ever concieved.
duster360 is offline
post #107 of 116 (permalink) Old 01-05-2011, 01:21 PM
New Member
Quoted: 0 Post(s)
young and dumb... and already lost all my lines
47# E3 meth fed
PT Cruiser....yup, i'm serious
Cheftank is offline
post #108 of 116 (permalink) Old 01-05-2011, 07:08 PM
kornsined's Avatar
Quoted: 4 Post(s)
This may be a stupid question, but does this render the Mopar toys useless now? The HOM would likely still work but would DAB? I'm assuming if DAB did still work it would cap the max boost.
FP Green Stage 3. Tuned by mindmelt101.
kornsined is offline
post #109 of 116 (permalink) Old 01-05-2011, 08:49 PM
New Member
Dragvan's Avatar
Quoted: 0 Post(s)
Originally Posted by KBzPTGT View Post
could this be done on a ptgt auto?
Remeber the 4th in those autos are weak. I recently asked Duster to see if he could lower the boost just in my 5th gear for highway use and not effect the BPG in the other gears. As usual Duster got it to work ,now my 5th is he same as 2nd gear. May want to see if this can be done to save the tranny life.
Quickest stock turbo SRT-4 on the planet
ZOMBIE 2003 SRT-4
Syked ECU Tune.
[email protected]
Car tuned by Resaik Engineering
Best 60ft 1.605 on 23x7.5 slicks
Best 1/8th 7.249 Best 1/8th mph 95.33
Best 1/4 mph 117.89
https://www.srtforums.com/forums/f56/...broken-636326/ first post for slips and video
Dragvan is offline
post #110 of 116 (permalink) Old 01-06-2011, 07:02 AM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
I haven't specifically tested DAB affect on BbG but this is how it should "work":
The PCM should use the LOWEST desired Torque.
If, for example, 2nd Gear is only 300Nm, DAB0 will kill ALL torque and will take precedance so boost will be only as high as the wga spring allows.
DAB1/2 will all be some scalar multiple of the Desired Torque table which values will be higher than 300Nm at WOT. In these cases, BbG's lower 2nd gear Torque of 300Nm should take precedance but DAB1/2 higher boost in 3/4/5 will act as normally.
DAB3 may actually wipe out all Torque limits for Gear, MPH, RPM, Coolant temp,ect. In this case DAB3 will run high boost in all gears/speed. But like I said, I haven't specifically tested it.
post #111 of 116 (permalink) Old 01-06-2011, 07:04 AM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Right,,I should be able to lock down the max boost level just when in overdrive as a safty measure.
post #112 of 116 (permalink) Old 01-06-2011, 08:24 AM
KBzPTGT's Avatar
Quoted: 5 Post(s)
interested if i hadn't purchased a n2mb box... and already did the solenoid delete ghetto mod and too lazy to put things back
nice work though
ps- incase your wondering i am faster than ^^^^^^^
i so wish i had the time & a way to help test this for us slightly built auto guys
& fixed
KBzPTGT is offline
post #113 of 116 (permalink) Old 01-06-2011, 06:10 PM
Crazyced's Avatar
Quoted: 161 Post(s)
You say wipe out all torque limits but it should't affect/override the tune even if it's set to higher boost then stock DAB level right?
If not then it gets really interesting. DAB2 with your BbG and DAB3 for slicks.
Crazyced is offline
post #114 of 116 (permalink) Old 01-06-2011, 07:37 PM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Thats what I'm thinking.
post #115 of 116 (permalink) Old 01-08-2011, 07:18 PM
New Member
93stang434's Avatar
Quoted: 0 Post(s)
This spring you want to give it a shot?
The only thing i would have to do is put a softer spring in the waste gate and hook the wires on the solenoid back up.
Strapped block,ion crank,JE pistons,MAP rods,cncport.com head,HVF tubular top mount.PTE dbb 6266 .82 ar,JMFab intake manifold and some other stuff=Aiming for the 10s on E85
BC co's,Hotchkiss sways,Prothane bushings,Pwerks strut bars,Mopar tension struts
93stang434 is offline
post #116 of 116 (permalink) Old 02-26-2017, 06:18 AM
Quoted: 2 Post(s)
Originally Posted by Gizmodo View Post
lol, I love the honesty!
....or maybe he's a business man who isn't going to give you the name of his competition?
MustangSRT420 is offline
User Tag List
Linear Mode Linear Mode
