How to set up AFR on DS Intune - Page 4 - Dodge SRT Forum
 2Likes
post #46 of 73 (permalink) Old 07-02-2013, 04:31 PM
New Member
Quoted: 0 Post(s)
I reverted back to 3.3.08 and it works fine. 09 froze on me while "acquiring tool info"...
so can I get my DSP to recognize and record off of an AEM UEGO wideband?
SST turbo. DSP(93oct). Greddy type-S bov. Crower S1 cams. Granetelli coil and wires. NGK Iridiums gapped at .50. AGP solid motor and trans mount. MPX catch can. Pwerks S1 trans w/ spec clutch(s2+). Gutted cat.
BoostFeverPA is offline
post #47 of 73 (permalink) Old 07-02-2013, 09:19 PM
Crazyced's Avatar
Quoted: 161 Post(s)
No. You need an intune or a trinity for that.
Crazyced is offline
post #48 of 73 (permalink) Old 07-03-2013, 12:30 PM
New Member
Quoted: 0 Post(s)
Does anybody even buy dsp anymore? Sad part is I bought it just before the trinity came out and just now started really using it to log/tune rather than just read codes and run the 93tune and now I'm finding out its pretty much an old relic...
post #49 of 73 (permalink) Old 07-26-2013, 10:05 AM Thread Starter
SRT of the Month
underSRTarmor's Avatar
Quoted: 4 Post(s)
To top
TUNED By MindMelt101
MyBuild Thread
10.99 @132.23 1.70 60ft 27 psi
Need Fuel setup ideas click here
Props go out to:
Mindmelt101, Tuner Geeks, Act, Wikyd Performance, Pwerks
underSRTarmor is offline
post #50 of 73 (permalink) Old 01-17-2014, 10:35 AM
New Member
Romeo21's Avatar
Quoted: 0 Post(s)
I just got my intune and it doesn't have the 93 tune just a "diablo tune" and "modify stock tune"
Romeo21 is offline
post #51 of 73 (permalink) Old 02-19-2014, 07:25 AM
Quoted: 1 Post(s)
Link for the intune application to enable analog input tool logging
https://www.dropbox.com/s/4gyl3ngho9...t_mhAnalog.itf
EDITED
Mindmelt101 is offline
post #52 of 73 (permalink) Old 02-19-2014, 08:53 AM
cano's Avatar
Quoted: 26 Post(s)
Link dosen't work, interested
Thanks
New Setup - CP Pistons, Carillo Rods, Built head, BC S2 Cams, Precision 6266 JB Turbo, Intune (Tuned by Nigel), Dual intank 450s, 3" turboback Dump, AGP Motor Mounts, Spearco FMIC, Fuel Return Kit, Engine built be Omnidawg in Dallas with specs from Raceeng.com, Liberty Gearset, twin CM Clutch, M/H Slicks Rota Slipstreams, BC Coilovers, Wykedperformance LCA, Darkside & ZHP Support and Driver Mod
cano is offline
post #53 of 73 (permalink) Old 02-20-2014, 07:24 AM
Quoted: 1 Post(s)
Thanks
New link https://www.dropbox.com/s/4gyl3ngho9...t_mhAnalog.itf
post #54 of 73 (permalink) Old 04-17-2015, 10:21 PM
Quoted: 75 Post(s)
NTK AFR data logging glitch
If you buy an NTK from NGK you will find a big problem with logging AFR on the intune. Every other analog output I've seen is 0-5V. It's the standard everywhere, but NGK decided to be different. The output from the AFR gauge is 0.5V to 4.5V. They also changed the AFR range from the previous model, the AFX.
This causes a big issue with the Intune because it is expecting 0 to 5V.
Jondahl is offline
post #55 of 73 (permalink) Old 04-20-2015, 10:39 AM
Gizmodo's Avatar
Quoted: 95 Post(s)
As long as the slope of the analog output is constant it doesn't matter. Given the two points (.5 and 4.5) you can determine the slope and therefore determine what the 0 and 5 volt values would be.
Gizmodo is offline
post #56 of 73 (permalink) Old 04-20-2015, 08:27 PM
Quoted: 75 Post(s)
Yes,I calculated the the endpoints a while ago. JEGS has these, and the catalog says the output is 0-5V. I certainly hope they changed it. I had misplaced my tiny manual and didn't understand what was happening until I found it.
Jondahl is offline
post #57 of 73 (permalink) Old 09-18-2015, 08:23 PM
Roast's Avatar
Quoted: 14 Post(s)
Thanks
Link doesn't work... Anymore?
Roast is offline
post #58 of 73 (permalink) Old 09-20-2015, 09:37 AM
Roast's Avatar
Quoted: 14 Post(s)
What do you mean channel 1 or channel 2? I don't understand. When I hooked up my wideband was I supposed to use the little grey wire, plug it into the displays harness and then into my ecu somewhere? I have a PLX gen 4.
Roast is offline
post #59 of 73 (permalink) Old 09-22-2015, 10:31 AM
Roast's Avatar
Quoted: 14 Post(s)
I found out that I did not get the "diablosport analog cable" when i purchased my intune. I understand now, with that cable there will be ground wires and 2 other wires, hence channel 1 or channel 2, and of course on the other end a 2.5mm jack to plug into the intune. I will be hooking my plx wideband up to channel 1 and the other end to the analog of the sm-afr unit bottom right spot explained in step 5 on the plx sm-afr user guide. I ordered the cable and should be logging in no time!
Roast is offline
post #60 of 73 (permalink) Old 11-02-2015, 07:51 PM
Quoted: 410 Post(s)
Ok, once you set up the intune for the analog input, how do you get it to log analog data? Is it automatic? The car I bought has an intune with the AFR cable supposedly already hooked up. I don't see any external inputs on my data viewer. I went through the setup twice and get no analog data when doing a log. Maybe the wires are disconnected? I never touched that part of the car during the rebuild.
Edit: Checked the wiring. It's right. I just don't see any analog data in the log. Do I have to use a laptop to make it work?
2005 SRT-4, 47lb wheel Stage 3, E85...
2002 Camaro SS M6, PTE 7675 Turbo, E85...
2003 SRT-4 Sold!
enginjoe is offline
User Tag List
Linear Mode Linear Mode
