How To:---->DSP DST tune files - Page 2 - Dodge SRT Forum
 1Likes
post #16 of 25 (permalink) Old 02-25-2015, 12:48 PM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Originally Posted by varnadoe View Post
I just got a dsp and I'm wondering how does it work with agp waste gate , is there anything I need to change
First off the stock wga + Diablo tune works nearly as well to hit ~22psi, so the AGP is most often a waste of money. pissing money away on a WGA a perpetual noob F'up.
AGP MUST have an 8# spring to work at all on PCM boost control + Diablo tool. 8psi springs are available from AGP for ~$20
After you get the 8# spring installed do this:
1. Connect WG directly to the Turbo and adjust the preload so that you have ~8psi
2. Connect the WG back up to the WG solenoid
3. Clear PCM memory with a battery disconnect
4. With the STOCK TUNE flashed and engine over 170F, make several WOT pulls to allow PCM to relearn wga settings and stabilize boost.
5) Flash Diablo tune
You should wind up ~20-24psi(same as with stock wga) and can lower boost if needed with the Diablo tool
duster360 is offline
post #17 of 25 (permalink) Old 02-25-2015, 09:19 PM
New Member
Quoted: 3 Post(s)
I bought the car like that ! So what your telling me is that I need to put the car back on stock program so that the agp will work properly, because it is over boosting and running like shit in boost mode. And yes I am a noob thanks!
varnadoe is offline
post #18 of 25 (permalink) Old 02-25-2015, 09:29 PM
Crazyced's Avatar
Quoted: 161 Post(s)
Start by loosening the WGA arm so that you boost less for now. Then order a 8lbs spring and follow his steps.
duster360 likes this.
Crazyced is offline
post #19 of 25 (permalink) Old 02-25-2015, 10:50 PM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Personally I'd put on a stock wga and sell the AGP to the next noob.Then use the extra cash to buy 3bars and one of my Rescale tunes.
If you keep the AGP, it will NEVER stop over boosting unless it can be adjusted down to 8psi as stated in step #1 of my instructions.
post #20 of 25 (permalink) Old 02-26-2015, 06:22 AM
New Member
gski4life's Avatar
Quoted: 8 Post(s)
^^^this guy speaks the truth...I forgot about the 8lb spring they have
gski4life is offline
post #21 of 25 (permalink) Old 02-26-2015, 08:49 AM
New Member
Quoted: 3 Post(s)
Thanks for the help
varnadoe is offline
post #22 of 25 (permalink) Old 03-09-2015, 04:00 PM
angel0410's Avatar
Quoted: 80 Post(s)
Nice info man, I got a question though do I still have to do this if I am not on pcm control boost?
angel0410 is offline
post #23 of 25 (permalink) Old 03-09-2015, 04:02 PM Thread Starter
duster360's Avatar
Quoted: 139 Post(s)
Stock turbos should always be on PCM boost control.
post #24 of 25 (permalink) Old 03-09-2015, 04:05 PM
angel0410's Avatar
Quoted: 80 Post(s)
OK so this info is only for stock turbo, I'm not on stock turbo so I'm good thanks man
post #25 of 25 (permalink) Old 03-10-2015, 05:25 PM
New Member
Quoted: 3 Post(s)
Just wondering is there anyone in middle Georgia area
varnadoe is offline
User Tag List
Linear Mode Linear Mode
