have a couple questions regarding lean afr after 93 dsp tune - Dodge SRT Forum
post #1 of 17 (permalink) Old 05-26-2011, 04:37 PM Thread Starter
New Member
racemycobra's Avatar
Quoted: 0 Post(s)
to start off mods are.. 3 inch turbo back exhaust, big front mount intercooler, aem cold air intake, and the dsp. now i installed the 93 canned tune from my newly purchased dsp spiking 22psi and dropping to roughly to 15-16 psi at redline. ... i tuned it myself to the point of no knock and 30 degrees of timing at the end of 3rd gear... these are 3rd gear pulls starting at 2500 rpm to redline. my air fuel ratios were in the high 12's sometimes touching 13... i added fuel (i am up to 5.5% added from 2k and up) and it seems i am still running lean? 12.4-12.6 area... is this common to have to add this much fuel after flashing the 93 tune? i have heard possibly the fuel filter (fuel pump sock) could be clogged? which is kind of hard to believe...in my 7 years of being an auto mechanic it is a very uncommon issue as my car only has 40,000 miles on it. anyone have any ideas as to what i can try?
racemycobra is offline
post #2 of 17 (permalink) Old 05-26-2011, 04:40 PM
Fresh Meat Moderator
Quoted: 3 Post(s)
The 93 tune can run lean on most cars.
Add more fuel till you get below 12.0.
tunerlover3 is offline
post #3 of 17 (permalink) Old 05-26-2011, 06:34 PM Thread Starter
New Member
Quoted: 0 Post(s)
yeah thats pretty much what i figured... but i didn't know if adding 6%+ fuel across the rpm band was normal... this is a 2004 srt4 btw.. also when hitting below 12.0 afr should the afr stay steady across the rpm band? or is it going to jump around a little?
post #4 of 17 (permalink) Old 05-26-2011, 06:53 PM
Quoted: 3 Post(s)
Its going to jump around a little cause you cant get it perfect. You can get it extremely close to being the same through out the power band.
post #5 of 17 (permalink) Old 05-26-2011, 10:13 PM
SRT of the Month
underSRTarmor's Avatar
Quoted: 4 Post(s)
u really need the 3 bar sensor, being that you 4 psi over the max the stock sensors can ready...
best 450 i spent in my life duster 1025 cc injector 3 bar sensors and a pump gas and race gas(e85 in my case) tune
TUNED By MindMelt101
• MyBuild Thread
• 10.99 @132.23 1.70 60ft 27 psi
• Need Fuel setup ideas click here
Props go out to:
Mindmelt101, Tuner Geeks, Act, Wikyd Performance, Pwerks
underSRTarmor is offline
post #6 of 17 (permalink) Old 05-26-2011, 10:26 PM Thread Starter
New Member
Quoted: 0 Post(s)
definitely going to consider this in the near future
post #7 of 17 (permalink) Old 05-27-2011, 02:04 PM
New Member
thej's Avatar
Quoted: 0 Post(s)
450 for injectors, sensors, -and- pump/e85 tune?
thej is offline
post #8 of 17 (permalink) Old 05-27-2011, 06:19 PM
SRT of the Month
Quoted: 4 Post(s)
duster sell the injectors for 389 with 2 tunes( rescales)
25 for map dealership caliber map
25 for tip dealership caliber map
and 30ish for adapter to map
about 450
• MyBuild Thread
Props go out to:
post #9 of 17 (permalink) Old 05-27-2011, 07:14 PM
New Member
thej's Avatar
Quoted: 0 Post(s)
with the tunes thrown in that is a damn good deal.
thej is offline
post #10 of 17 (permalink) Old 05-27-2011, 07:32 PM
Quoted: 3 Post(s)
They are not full blown tunes but injector rescales.
The tune is extra.
post #11 of 17 (permalink) Old 05-27-2011, 10:11 PM
SRT of the Month
Quoted: 4 Post(s)
The tune is extra.
that is correct i should of worded it better.. sorry about that....
but these rescales are awesome... i think my pump gas i had to add alil fuel to 4-6k
and the e85 add some timing and they are really good...
• MyBuild Thread
Props go out to:
post #12 of 17 (permalink) Old 07-10-2011, 03:22 PM
New Member
The Game's Avatar
Quoted: 0 Post(s)
I take it that you can get the 1025s w/ the rescale and run e85 safely on the stock fuel lines as long as its just track days, run it low then fill up w/ 93 and flash the 93 tune again? I know its fairly rough on standard lines. I'd like to run e85, which is available at pumps around the track I go to. Closest one to where I live is like 70 miles away.
BST Head, BST Long Block, Crane 16s, S256 .63, FIC 1100s, Full Blown Perf twin 290s -8F -6 R, MPx 3" TBE, AGP 4" CAI, TG FMIC, N2MB 2-Step/WOT Box & Boost Box, ACT HD 6 Puck Clutch, Snow 2 W/M, DCR oil pump and Windage tray
4**HP/4** TQ TDS Mustang Dyno and 93 and meth (Turbo666 built and dyno tuned)
The Game is offline
post #13 of 17 (permalink) Old 07-10-2011, 04:09 PM
Quoted: 3 Post(s)
Im running E85 on all stock lines with just a 255 and dusters injectors and I have no issues.
post #14 of 17 (permalink) Old 07-10-2011, 04:19 PM
New Member
The Game's Avatar
Quoted: 0 Post(s)
That is flippin sweet. And damn, I just sold my unused 255 to a buddy haha.
The Game is offline
post #15 of 17 (permalink) Old 07-10-2011, 10:36 PM
Quoted: 3 Post(s)
You can run it on the stock pump, but its just better to have the 255.
User Tag List
Linear Mode Linear Mode
