Help! - Frozen trans bellhousing bolt above distance sensor - Dodge SRT Forum
post #1 of 9 (permalink) Old 04-23-2019, 07:42 PM Thread Starter
New Member
Quoted: 0 Post(s)
I am trying to replace the clutch on a 2003 SRT-4. The trans has never been pulled out before. Having a problem with the bellhousing bolt that is on the engine side above the extension housing and distance sensor and screws into the trans casing. It is frozen. I have tried breaker bars with a lot of leverage and an electric impact wrench, and it won't budge. I saw some writeups on pulling the trans referring to this one as the "bitch bolt". Just wondering how others have managed to break this one loose?
[email protected] is offline
post #2 of 9 (permalink) Old 04-23-2019, 08:46 PM
Super Moderator
RTShadow's Avatar
Quoted: 6 Post(s)
Garage
Are you able to get any heat on it? If I remember correctly it is in a pain in the butt location that requires at least one 1/2" or greater breaker bar?
RTShadow is offline
post #3 of 9 (permalink) Old 04-24-2019, 04:48 AM
gump1114's Avatar
Quoted: 104 Post(s)
Garage
i would try soaking it with some good penetrating oil and then trying again.
435 HP & 438 TQ -E85
Tuned by Turbo666 on his mustang dyno
Best ET to date: 12.1 @ 124 on DR's
gump1114 is offline
post #4 of 9 (permalink) Old 04-24-2019, 08:38 PM Thread Starter
New Member
Quoted: 0 Post(s)
Thanks. I just have a basic Benzomatic which wasn't any help. Have it soaking overnight and someone coming over with a proper torch tomorrow if that doesn't work.
post #5 of 9 (permalink) Old 04-25-2019, 01:07 PM Thread Starter
New Member
Quoted: 0 Post(s)
The overnight soak and bigger breaker bar on a swivel socket did the trick. Thanks for the suggestions. Got the trans out and ready to put it back in when we ran into a problem with the new release bearing. I purchased the Sachs combo kit from Rockauto that includes the new release bearing. Unfortunately the bearing was just floating around in the package with the clutch, and one of the 2 plastic retaining tabs was broken off of the release bearing during shipping. I'm assuming that the release bearing can't be used without both tabs, or are they just to aid in assembly?
post #6 of 9 (permalink) Old 04-28-2019, 08:28 PM
"Made" Member
HybridKid's Avatar
Quoted: 1175 Post(s)
It will be noisy, it is meant to have the TOB stay with the fork and not move back and forth and not to ride against the pressure plate tangs.
HybridKid is offline
post #7 of 9 (permalink) Old 04-28-2019, 10:08 PM
Quoted: 289 Post(s)
Might want to put a little anti-seize on those bolt threads for good measure when you re-assemble.
Simon.Starkie is offline
post #8 of 9 (permalink) Old 04-29-2019, 12:29 AM
T4EaterJonny's Avatar
Quoted: 424 Post(s)
Garage
I was going to suggest that^. Glad you got it loose. If pb blaster or Kroil doesn't work, ATF does. Got my seized coilover collar rings loose.
Big wheel stage 3, E85, 171k on body. (3/11/2019) Will be repainting soon pop my hood red.
BC rods, JE pistons stock 8:1 .020 over, BS delete.
Sways & STbraces, coilovers valved by Feal, DIY solid control arms.
Have you driven an SRT-4?... Lately?
T4EaterJonny is offline
post #9 of 9 (permalink) Old 04-29-2019, 12:35 PM Thread Starter
New Member
Quoted: 0 Post(s)
Thanks for the tips. I picked up another throwout bearing and put some antiseize on the problem rear housing bolt.
User Tag List
Linear Mode Linear Mode
Similar Threads
Am I The Man Or What ? djgainsbond SRT-4 Discussion 16 07-18-2007 10:28 PM
p2074 red Midwest 86 11-19-2006 05:50 PM
SRT-4: Understanding OBD II (On-Board Diagnostics II) NeonDan SRT-4 Discussion 19 11-29-2005 11:26 PM
Technical: The Lowly Oxygen Sensor hemidakota Technical Tuning & EFI/EMS Electronics 7 06-16-2004 05:02 PM
Help CEL I don't know why! htx SRT Problems & Dealer Service 9 03-19-2004 05:36 PM
