Serious car issue - Page 2 - Dodge SRT Forum
post #16 of 19 (permalink) Old 05-15-2019, 04:51 PM
DerrickA's Avatar
Quoted: 2 Post(s)
Garage
You really need to be familiar with how this system works, and a decently experienced mechanic to diagnose problems like this. You can't just run an air line to a vac port and test for boost leaks, without blocking the turbo inlet, and the intake manifold. At any given time, a cylinder may be on the exhaust/intake crossover, where both valves will be open allowing air to pass straight through the engine while it is off. I have had the most success with actually inspecting every inch of the charge plumbing from turbo to throttle body, and then test driving. After that, make sure all your small plumbing to the turbo, WG actuator, BOV, and solenoids is 100% correct, and in great shape. Lastly there is the Actuator linkage, make sure that is attached to the wastegate, with the pin in place, if you have an adjustable WG, it may need to be properly adjusted.
Derrick Argabright
DerrickA is offline
post #17 of 19 (permalink) Old 05-16-2019, 05:28 PM Thread Starter
New Member
Quoted: 2 Post(s)
Originally Posted by fivetoez View Post
I had a blocked cat and it was still noisy as usual.
What was your car doing symptom wise with the blocked cat
Pwnr is online now
post #18 of 19 (permalink) Old 05-18-2019, 09:36 AM
Quoted: 84 Post(s)
Find someone local to look over the car, that knows the Neon SRT-4 well. 12's is very lean on pump gas at WOT.
05 PW1 SRT-4
AGP 50 trim and supporting mods
s3*ps2 is offline
post #19 of 19 (permalink) Old 06-12-2019, 11:31 PM Thread Starter
New Member
Quoted: 2 Post(s)
I just wanted to finish up this thread by saying I fixed my problem turned out to be a clogged cat. Took the cat off kicked it in the garbage and put on a cat less downpipe. Thanks to all for helping.
Pwnr is online now
« Parts | -
User Tag List
Linear Mode Linear Mode
Similar Threads
Mustang owner gets screwed (Good Read) Gator General Car Discussion 15 08-05-2004 02:19 PM
Car Names Explained...add yours! LOL hemidakota General Car Discussion 5 08-03-2004 11:50 PM
Got my car today :) - Thoughts on it all (very long meandering post) LiveWire SRT-4 Discussion 10 04-29-2004 07:39 AM
Twin Turbo Tech 101 hemidakota Performance Modifications 13 01-25-2004 07:19 PM
transmition grinding?? please read superstrongbeast SRT Problems & Dealer Service 25 11-12-2003 10:48 AM
