Please help LSD question? - Dodge SRT Forum
 1Likes
  • 1 Post By Simon.Starkie
post #1 of 11 (permalink) Old 04-05-2019, 12:27 PM Thread Starter
Yellowneon's Avatar
Quoted: 3 Post(s)
as it states. I found out the lsd or diff gear is all chipped up,
trying to figure out a part number for just the gear.
does anyone have a part number for this gear ? or proper name ? I will attach a pic for a better idea.
Click image for larger version
ID:	138131   Click image for larger version
Yellowneon is offline
post #2 of 11 (permalink) Old 04-05-2019, 12:55 PM
"Made" Member
HybridKid's Avatar
Quoted: 1178 Post(s)
Not sure you can get the gear separately, thought the LSD was only available as a unit. These days with the scarcity of transmission parts, even if they were available before, they probably will be difficult to find now.
With that ^^^^ said I just looked and Modern has it.
T-850 Differential Components, 04-05 Neon SRT-4, Transmission: Store Name
HybridKid is offline
post #3 of 11 (permalink) Old 04-05-2019, 01:14 PM
Quoted: 302 Post(s)
I see the ring gear for $325 but not the pinion which probably also needs replacing.
I could be wrong, but always thought those two components are best installed as a matched set.
Ring and Pinion install may involve shims, dial gauge and blue marker etc to install correctly so it's quiet and lasts.
Just because its a FWD doesn't alter the fact that it's still a ring and pinion just like a RWD.
When my 03 was upgraded to LSD, the whole thing, including ring and pinion and LSD, came as a unit.
It wasn't cheap, about $1100 in 2003, but I see MP now has it discounted for $750.
Mine was probably all setup by Quaife which is probably why it has lasted and is still is relatively quiet after 125k miles.
Anyway, good luck!
ps you may have other issues that caused the ring gear damage...so it may be wise to check further.
HybridKid likes this.
Simon.Starkie is offline
post #4 of 11 (permalink) Old 04-05-2019, 03:10 PM Thread Starter
Yellowneon's Avatar
Quoted: 3 Post(s)
Well thanks for the advice guys. My friend rebuilt a few gears and put new bearings and shift forks, I hope to god that the internals are ok . there was a lot of metal in the diff housing with the magnet if you look at my pic you'll see it, I pulled out what looked like a c clip off a bearing and it got chewed up. the lsd its self is fine so the gear runs $324 off modern performance from what you guys have told me. might have an easy lsd fix , but the input shaft might have taken a hit too if that's the case im not in a position to fix it further because parts are ridiculous for these cars. But im glad I looked because this would have came back and haunted me later if I didn't.
post #5 of 11 (permalink) Old 04-06-2019, 11:24 PM
lilviper's Avatar
Quoted: 29 Post(s)
If you think these cars are nuts dont try and replace the variator in a CVT. Lol. That part costs more than most SRTs.
SM-G960U using Tapatalk
lilviper is offline
post #6 of 11 (permalink) Old 04-14-2019, 11:43 PM Thread Starter
Yellowneon's Avatar
Quoted: 3 Post(s)
Well removed the gears doesn't look as bad as all the metal shavings and chipped teeth on the gears are . Turns out a couple chipped lsd teeth . But those can be welded mild steel no issues there. The main shaft I think it's called if possibly weldable but time will tell , I'm gonna try to fix it .
ID:	138179   Click image for larger version
post #7 of 11 (permalink) Old 04-15-2019, 11:26 AM
"Made" Member
HybridKid's Avatar
Not heard of welding gears. Good luck. Personally I would replace them if they looked like these.
post #8 of 11 (permalink) Old 04-15-2019, 11:41 AM Thread Starter
Yellowneon's Avatar
Quoted: 3 Post(s)
@ HybridKid
I would replace it if was like $200 or so but not $1300 . that crazy, yeah you can weld mild steel its not that hard its just a gamble i am willing to take. think of it this way .
ive had machine shops weld crankshafts its the same concept . i just need it to drive for now then later buy a pwerks tranny or a dcr one.
post #9 of 11 (permalink) Old 04-15-2019, 01:16 PM
Gizmodo's Avatar
Quoted: 100 Post(s)
You may as well just buy a new transaxle and save the money you'd spend on "repairs".
Gizmodo is offline
post #10 of 11 (permalink) Old 04-15-2019, 01:41 PM Thread Starter
Yellowneon's Avatar
Quoted: 3 Post(s)
What do mean trans axle ? are you taking about the input shaft?
post #11 of 11 (permalink) Old 04-15-2019, 07:57 PM
blackbird_R/T's Avatar
Quoted: 127 Post(s)
Transaxle = front wheel drive transmission and differential assembly combined into one unit.
I'd also suggest finding a used trans or parts to rebuild. There's a good chance the parts are heat treated and if the welding came apart might take out the rest of the internals.
If you have no other option and it's essentially free, maybe it's worth a shot, but if you're spending a lot of money on bearings and seals at a bare minimum for a partial rebuild you'd have to have a extremely experienced welder and machine show that can check the surface hardening and material used by the factory components and then they'd have to be able to machine it perfectly afterwards for proper gear mesh.
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '92 Dodge Daytona IROC R/T
'91 Dodge Spirit R/T - '19 Pacifica Hybrid Limited - '14 CTS-V Wagon
'08 Cobalt SS Turbo - '14 Cruze Turbo Diesel - '02 SVT Focus (S/C)
'04 SVT Focus (EAP) - '07 Ram 1500 - '81 & '85 Chevy Citation X-11
'90 Pontiac Turbo Gran Prix (ASC/McLaren) - '93 Olds Achieva SCX W41
blackbird_R/T is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
Just a question lsd trans Yellowneon Drivetrain Discussion 7 02-02-2019 06:06 AM
Mopar LSD Installation Question TomSlick Performance Modifications 1 11-25-2003 11:04 PM
Mopar LSD question srt4hokie SRT-4 Discussion 4 10-13-2003 07:51 AM
Top 5 Mods? turbo4life Performance Modifications 49 09-09-2003 07:39 PM
LSD question PVOJam Performance Modifications 19 06-07-2003 10:00 AM
