Parts List for Adding -6 Fuel Filter w/stock line&Pump Mods - Dodge SRT Forum
 8Likes
post #1 of 33 (permalink) Old 02-07-2019, 04:42 AM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
can't seem to find part numbers for building a -6 e85 fuel system using the stock feed line.
i'll add a large fuellab filter for e85 with -6 , but what fittings are needed to add it?
also fittings and misc needed to put my 255 pump in the stock canister
i've read the post '' e85 questions , with about 11 pages ....
anyone have a simple parts list w/part no. and where that part goes in the fuel system ?
valvefloat is offline
post #2 of 33 (permalink) Old 02-07-2019, 04:59 AM
gump1114's Avatar
Quoted: 92 Post(s)
Garage
Sorry i do not have a list of all parts needed, but i can try to start you in the right direction. but first...
is your 255 a direct stock replacement 255? if so, there shouldnt be any extra parts needed. just follow this
https://www.srtforums.com/forums/f75...nstall-188152/
as for hooking up to the stock hard line, i used one of these fittings which attaches at the firewall.
http://fullblownmotorsports.com/fuel...ick-disconnect
HybridKid likes this.
435 HP & 438 TQ -E85
Tuned by Turbo666 on his mustang dyno
Best ET to date: 12.1 @ 124 on DR's
gump1114 is offline
post #3 of 33 (permalink) Old 02-07-2019, 06:37 PM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
Thanks for the help Gump....Full Blown has some special fittings i'll need
this is the 255 pump kit i was looking to buy from Modern
second pic is what i think i need for fittings and installing 255 into canister
third is fittings i believe i'll need but w/o that filter
fourth - this is how i want to mount my Fuelab 828 Filter.... what fitting's do i need?
5- is this how i need to route lines?
Lastly.... i get this a lot when trying to research and learn... can't get pictures.
Pic's help a lot , but can't get because post are too old?
some of this info goes back to 2005. Which makes me think vendors have put out updated... better refined part's today
i'm sure i'm going to buy stuff that i don't need, so suggestions for the right part's Greatly Appreciated
Click image for larger version
Name:	IMG_4095 (Small).PNG
ID:	137977   Click image for larger version
Name:	IMG_4096 (Small).PNG
ID:	137979   Click image for larger version
Name:	IMG_4093 (Small).PNG
ID:	137981   Click image for larger version
Name:	IMG_4094 (Small).PNG
ID:	137983   Click image for larger version
Name:	IMG_4092 (Small).PNG
Name:	IMG_4097 (Small).PNG
post #4 of 33 (permalink) Old 02-08-2019, 04:07 AM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
i'll be using AGP return line kit from Modern..... so i will only need one -6 for feed out of pump
i believe pictures are showing return going back to pump
post #5 of 33 (permalink) Old 02-08-2019, 01:51 PM
"Made" Member
HybridKid's Avatar
Quoted: 1175 Post(s)
Sorry, I can help much here. I was going to do something like this but went another route.
HybridKid is offline
post #6 of 33 (permalink) Old 02-08-2019, 11:08 PM
dirtbag's Avatar
Quoted: 54 Post(s)
It may not be exactly what you're seeking, but there may be some part numbers you can steal from this thread (maybe some of the fittings), they should be somewhat current:
https://www.srtforums.com/forums/f18...post1073796873
dirtbag is offline
post #7 of 33 (permalink) Old 02-09-2019, 07:02 PM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
thanks for the link dirtbag...... has a lot of good info, i'll be ordering fittings , lines and other misc. items because of this post
post #8 of 33 (permalink) Old 02-17-2019, 05:51 AM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
what is the spacer for moving the thermostat housing for?
aftermarket fuel rail?
post #9 of 33 (permalink) Old 02-17-2019, 06:19 AM
gump1114's Avatar
Quoted: 92 Post(s)
Garage
Yes. It allows for a straight through connection of fuel lines without the need for a 90 degree elbow off the passenger side of the rail.
gump1114 is offline
post #10 of 33 (permalink) Old 02-24-2019, 11:34 AM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
so most guy's are using -6 for return when switching to a Big Turbo....
the AGP kit like from Modern , has a -4 return
anyone sell a -6 kit?
i would like to use my feed line for the return and go ahead and change/add -8 for the feed to a Full Blown rail,
i believe i'll need a "Aeromotive A1000-6 Injected Bypass Regulator 13109", it can accept -6 fittings
any info on making your own -6 return on SRT Forums ?
it's for a e85 build , want to have plenty of capacity
i'll still return it into the filler hose (changing -4 to -6 in the tube for filler hose) like "Aaronneon" did in 2006 post
Aaronneon return line installed! (pics)
post #11 of 33 (permalink) Old 02-24-2019, 07:50 PM
"Made" Member
HybridKid's Avatar
I basically made my own with 1/2" aluminum tubing. Both for the feed and return. I came from the Supra world and that still sticks with me to this day. But remember I am using a surge tank.
Gizmodo likes this.
post #12 of 33 (permalink) Old 02-26-2019, 09:24 AM
Gizmodo's Avatar
Quoted: 93 Post(s)
I used aluminum tubing as well, but I went with 1/2 inch and -8. -4 for return will work fine, but ideally you want a return that is as large, or larger than your feed. You don't want any pressure in there.
Gizmodo is offline
post #13 of 33 (permalink) Old 02-27-2019, 04:27 AM Thread Starter
valvefloat's Avatar
Quoted: 13 Post(s)
thanks for the help , starting to test assemble engine......
went with a aftermarket fuel rail.....is their any t-stat housing spacer's being made ?
been looking , no luck
Name:	IMG_4285 (Small).JPEG
ID:	138075   Click image for larger version
Name:	IMG_4287 (Small).JPG
ID:	138077   Click image for larger version
Name:	IMG_4281 (Small).JPEG
ID:	138079   Click image for larger version
Name:	IMG_4282 (Small).JPEG
post #14 of 33 (permalink) Old 02-27-2019, 05:02 AM
gump1114's Avatar
Quoted: 92 Post(s)
Garage
i tried to do a quick look around and havent found anywhere that sells them anymore. Rage-tek used to, but they scammed a bunch of people... i dont even know if things can be purchased from them anymore...
BUT, i can tell you i made my own. I used another thermostat housing and cut the flange that meets the head off and smoothed it out and used it as a spacer. obviously longer bolts and new gaskets are required.
gump1114 is offline
post #15 of 33 (permalink) Old 02-27-2019, 04:14 PM
Gizmodo's Avatar
Quoted: 93 Post(s)
I just used some sheet aluminum to make mine.
Gizmodo is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
New Parts!! Mopar Performance Clutch & Polyurethane Inserts ken830 SRT-4 Discussion 8 06-04-2004 08:29 AM
Parts List Help SilverBullet SRT-4 Discussion 4 03-28-2004 07:21 PM
Mopar Launches New Performance Parts abubamsry SRT-4 Discussion 6 11-17-2003 12:04 AM
