Help please issue is driving me crazy !! - Dodge SRT Forum
 1Likes
post #1 of 29 (permalink) Old 06-28-2019, 09:29 AM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Hey guys so I bought a 04 neon srt4 with 74k miles, light mods, agp gate, short shifter. Hks bov and a aftermarket ignition pack/wires..
So my issue if the car sits for over 13 hours it won't start with out a jump.. I've tested the alternator starter and battery and they are all good .. I unplugged the trunk light and went thru the car to make sure nothing stays on, the battery is refurbished but tested at 13.4 volts. What can the issue be ? Any input ?
Dannybsrt is offline
post #2 of 29 (permalink) Old 06-28-2019, 08:27 PM
Super Moderator
RTShadow's Avatar
Quoted: 6 Post(s)
Garage
Can you try a different battery?
RTShadow is offline
post #3 of 29 (permalink) Old 06-28-2019, 09:13 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Do you think its possible that the battery I have might have a bad cell that slowly dies? I'm going to go buy a new battery tomorrow and see what happens
post #4 of 29 (permalink) Old 06-28-2019, 09:28 PM
Quoted: 305 Post(s)
Could be a bad cell. Or just low cold cranking amps. Or a short elsewhere draining the charge.
But before you buy a new battery, a decent battery shop should be willing to test your old battery.
Also, if you end up needing a new battery, take the old battery to the store when you get it tested (i.e. don't take it in another vehicle...).
That way you will be able to get a prompt "core charge" if a new battery is required.
This would avoid the hassle of going back home to get the old battery etc etc.
Also, getting rid of an old battery can be difficult.
Simon.Starkie is offline
post #5 of 29 (permalink) Old 06-28-2019, 11:34 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Yeah I'll have to do that, worth a shot. I don't know what else could cause it to kill the battery, I've checked all the spots and nothing. But I'll buy a new battery and see what happens. thanks for the input guys I'm glad to see the srt4 community is still up and running
post #6 of 29 (permalink) Old 06-29-2019, 01:54 PM
Super Moderator
RTShadow's Avatar
Quoted: 6 Post(s)
Garage
Let us know, I've found some crazy things over time with batteries, most recently a battery from Walmart that failed after 6 months in my black Neon (that I just sold).
RTShadow is offline
post #7 of 29 (permalink) Old 06-29-2019, 09:36 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Yeah I bought the current battery refurbished from a place I've bought batteries before, but maybe it's a bad call idk. I'll buy a new battery monday and keep you guys updated. Besides that idk what else it could be, the previous owner did do a " mod " to the gas tank he did some rewiring Idk if that would have somthing to do with it ? He mentioned somthing about constant psi at WOT
post #8 of 29 (permalink) Old 06-29-2019, 10:01 PM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
A fuel pump Rewire is a very common mod, but should have nothing to do with your current issue. I think you’re on the right track with the battery.
435 HP & 438 TQ -E85
Tuned by Turbo666 on his mustang dyno
Best ET to date: 12.1 @ 124 on DR's
gump1114 is offline
post #9 of 29 (permalink) Old 06-29-2019, 10:10 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Gotcha, one thing I noticed the fuse under the car near the gas tank seemed to be damaged , would that have anything to do with it ? This is so frustrating its driving me crazy
post #10 of 29 (permalink) Old 06-30-2019, 12:06 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
How do I run a parasitic battery draw test?
Hey guys for those that know of my issue how my battery drains over night. I have a question. how would I perform a parasitic draw test ? I'd like to do this before I go buy a new battery and potentially spend 130 bucks and ruin a battery
post #11 of 29 (permalink) Old 06-30-2019, 01:13 PM
Super Moderator
RTShadow's Avatar
Quoted: 6 Post(s)
Garage
I'm moving your new thread into your existing thread. Please don't start multiple threads on the same issue.
Have you taken this battery into a local car parts store for a free evaluation of the battery yet?
RTShadow is offline
post #12 of 29 (permalink) Old 06-30-2019, 06:19 PM
"Made" Member
HybridKid's Avatar
Quoted: 1178 Post(s)
That fuse is from the pump rewire? There are no fuse usually in that location.
You could put an amp meter on the car and see if there is a draw, if there is, then start popping a fuse at a time and see if the draw stops. That would be the circuit draining the battery.
HybridKid is offline
post #13 of 29 (permalink) Old 06-30-2019, 10:10 PM Thread Starter
New Member
Dannybsrt's Avatar
Quoted: 5 Post(s)
Where would I put the amp meter to? That's what I was trying to figure out.
And I have taken the battery and it checked out, it a refurbished battery the guy at autozone told me it could have a bad cell and slowly drain.
post #14 of 29 (permalink) Old 07-01-2019, 08:09 AM
Gizmodo's Avatar
Quoted: 100 Post(s)
If you actually have a fuse by the tank for a rewire fix that. There's a reason fuses are close to the power source. Also, a relay does not belong under the car, it should be in the engine bay as well. Their location isn't your problem but they very well could be a problem down the road.
Gizmodo is offline
post #15 of 29 (permalink) Old 07-01-2019, 08:19 AM
"Made" Member
HybridKid's Avatar
Amp meters are connected in a couple of ways; inline with the the Positive from the battery and induction 'clamp' over the same Positive. A multimeter is usually used for inline.
User Tag List
Linear Mode Linear Mode
Similar Threads
Driving Schools in Houston Area? paintbaler1587 SRT-4 Discussion 8 05-30-2004 01:49 AM
SRT-4 and BOOST GAUGE gone CRAZY! ElectricBlue04 Performance Modifications 11 05-12-2004 07:23 AM
Can We Discuss All These Accidents That Have Occured, Its Getting Crazy .... JSRT4 SRT-4 Discussion 16 01-15-2004 10:46 AM
Driving a stick question. generallee SRT-4 Discussion 3 02-27-2003 08:05 PM
Back from SRT-4 driving school =) daytonagts SRT-4 Discussion 27 01-16-2003 06:24 PM
