Crank Seal - Dodge SRT Forum
 7Likes
  • 2 Post By SilverBullet
  • 1 Post By lVlemphizStylez
  • 4 Post By SilverBullet
post #1 of 9 (permalink) Old 05-25-2019, 08:27 AM Thread Starter
SilverBullet's Avatar
Quoted: 12 Post(s)
Crank Seal
Gods of timing belt, pulley, and seals, grant me the sanity
to accept the tools I do not know how to use;
courage to change the crank seal and water pump;
and wisdom to know not to let the cam gears spin on their own
as gear locking and cam fixture tools are not in the moment.
Living one bolt at a time;
enjoying one pulley at a time;
wrenching in an open parking lot;
taking the input of the disciples
of the forums conceived with super off-topic;
accepting hardships as the pathway to the crank seal;
taking, as I do, this semi-inner side of the NSRT4 world
as it is, as PVO and SRT had it;
trusting that the 6667, 6792A, and 6793A will make all things right
if I brake them not, but surrender to their might;
that I may be reasonably speechless in this life
and supremely happy with the sprocket and cams aligned magically
forever...until a new timing belt is born.
Amen.
HybridKid and Simon.Starkie like this.
No car. Searching... Found it!
SilverBullet is offline
post #2 of 9 (permalink) Old 05-25-2019, 08:53 AM Thread Starter
Quoted: 12 Post(s)
Any suggestions on how to hold the MPx cam gears in place?
post #3 of 9 (permalink) Old 05-25-2019, 09:57 AM
Super Moderator
RTShadow's Avatar
Quoted: 6 Post(s)
Garage
How are they different than the stock gears? Forgive my question, I haven't seen them?
RTShadow is offline
post #4 of 9 (permalink) Old 05-25-2019, 10:18 AM Thread Starter
Quoted: 12 Post(s)
MPx:
Stock:
post #5 of 9 (permalink) Old 05-25-2019, 01:28 PM Thread Starter
Quoted: 12 Post(s)
By the looks of it, I might be able to hold things with a ghetto-made fixture (about to make one), with strap wrench. I just got the valve cover out and did some measurements. According to the receipts I got with my car, camshafts are BC stage 2 ( I really cannot tell staring at them directly. Clues?). The holes on the shafts where the fixture goes are about 5/16" dia., and 5.5" (outside edge of the two holes) apart.
post #6 of 9 (permalink) Old 05-25-2019, 07:49 PM
Quoted: 152 Post(s)
Garage
You use a cam fixture tool to lock the cams in place....it sits in the dowel holes on the cam shafts. It's literally a plate of sheet metal with two pegs in it that lock the cams at TDC
HybridKid likes this.
go ahead...change yours too now; again
lVlemphizStylez is offline
post #7 of 9 (permalink) Old 05-26-2019, 12:30 PM Thread Starter
Quoted: 12 Post(s)
Thanks. I followed your suggestion. Made one with 1.25" (max should be 1.5") x .25" bar, and I was able to get the cam and crank bolts loose. It worked
Click image for larger version
ID:	138223   Click image for larger version
ID:	138225   Click image for larger version
ID:	138227   Click image for larger version
ID:	138229   Click image for larger version
post #8 of 9 (permalink) Old 05-26-2019, 10:15 PM
T4EaterJonny's Avatar
Quoted: 432 Post(s)
Garage
You are my hero! I need to do a crank seal as well. Digging your progress! keep it up!
2005 Big wheel stage 3, E85, BC rods, JE pistons stock 8:1 .020 over, BS delete, Sways & STbraces, coilovers valved by Feal, diy NACHO solid control arms.
2004 C5Z06
94 XR600R
Have you driven an SRT-4?... Lately?
T4EaterJonny is offline
post #9 of 9 (permalink) Old 05-27-2019, 08:49 AM
Quoted: 292 Post(s)
That's one giant "attaboy" for making your own tool, one giant "props" for following good advice given freely here!
Simon.Starkie is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
Crank strap kit or non crank strap kit? 05'WhiteSRT-4 Performance Modifications 33 09-05-2018 09:59 AM
bad cam and crank sensors? solarCTsrt4 SRT Problems & Dealer Service 1 08-10-2004 01:07 PM
Who has info on the crank trigger/timing wheel? guhfluh Technical Tuning & EFI/EMS Electronics 4 01-07-2004 01:04 PM
2.0/2.4 (srt) crank similarity to the 2.2/2.5? cj011 Performance Modifications 20 10-11-2003 12:18 PM
Rear main seal is shot! paul544 SRT Problems & Dealer Service 13 07-05-2003 11:29 AM
