Car dying/not starting - Dodge SRT Forum
 1Likes
  • 1 Post By BrothaGrimm
post #1 of 12 (permalink) Old 04-19-2019, 01:07 PM Thread Starter
BrothaGrimm's Avatar
Quoted: 11 Post(s)
Garage
This all started a few weeks ago. The car started randomly dying at stops and wouldn’t start back up without sitting for 10-30 minutes . Then one day the car started reading lean At wot. So I had a spare stock fuel canister I just swapped them over. That fixed my lean problem. But now the car will still randomly die at stops, and if I turn the car off and run into a store or something I have to come out and wait for it to start. It’s not throwing a single code. I can hear the fuel pump priming and everything. It’s only threw a code once which was yesterday. Was driving down the interstate, lost throttle response and threw codes for all cylinder misfire and two codes for coil. I fixed that I found a short in the cam sensor. Car still is acting up. Will die at stops and won’t start back up without sitting.... im lost. It seems like the car will cool down some and boom start right up. Would the upstream o2 cause an issue like this?
04 srt4
Stage 1 Pcm, hks Bov, AGP wastegate, crappy eBay parts.
BrothaGrimm is offline
post #2 of 12 (permalink) Old 04-19-2019, 01:09 PM Thread Starter
Quoted: 11 Post(s)
Garage
Also would like to add the fuel canister I swapped had a modded fpr on it. The one with the extra washers and the plate. I guess it was made by ptp or someone at some point.
04 srt4
post #3 of 12 (permalink) Old 04-19-2019, 01:11 PM Thread Starter
Quoted: 11 Post(s)
Garage
And for some reason I can’t be edit my post. The car never had an issue starting up after I turned I told off before I changed the pump.
04 srt4
post #4 of 12 (permalink) Old 04-20-2019, 08:25 PM
"Made" Member
HybridKid's Avatar
Quoted: 1178 Post(s)
Have you checked the fuel pressure? Can you duplicate in your driveway?
HybridKid is offline
post #5 of 12 (permalink) Old 04-20-2019, 09:09 PM
Fischy's Avatar
Quoted: 11 Post(s)
BrothaGrimm,
Regarding the engine randomly dying at a stop or cutting out for a moment while driving. The wideband showed momentary rich spikes as the engine miss-fired.
A fresh NTK upper O2 sensor fixed the issue.
TD06SL2R 9 blade turbine, 20g 10 blade compressor Stage 3, Everything Ported, AGP Direct Fit I.C., 55 T.B., ACT, Thermal with Cat., and gutted BS housing.
Fischy is offline
post #6 of 12 (permalink) Old 04-21-2019, 08:41 AM Thread Starter
Quoted: 11 Post(s)
Garage
I haven’t been able to get the car to just die while idling in the driveway. It seems it dying at a stop is completely random. I have an 03 fuel rail I need to install to test the pressure though
04 srt4
post #7 of 12 (permalink) Old 04-21-2019, 07:42 PM Thread Starter
Quoted: 11 Post(s)
Garage
Originally Posted by Fischy View Post
BrothaGrimm,
Ok so I tried a new o2 sensor no luck still the same issue. No start after shutting the car off after a drive. Car will fire up if I try to start immediately after shutting it off. But if I wait a few minutes it’s a no go. I’m going to try and test the fuel pressure tomorrow. Anything specific I should look for?
04 srt4
post #8 of 12 (permalink) Old 04-22-2019, 06:45 PM
"Made" Member
HybridKid's Avatar
post #9 of 12 (permalink) Old 04-23-2019, 04:24 AM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
Pressure should be 58PSI constant.
*SHOULD* but if he has a modded FPR it will be higher.
just a thought... but when was the last time you cleaned the throttlebody/IAC...?
435 HP & 438 TQ -E85
Tuned by Turbo666 on his mustang dyno
Best ET to date: 12.1 @ 124 on DR's
gump1114 is online now
post #10 of 12 (permalink) Old 04-24-2019, 08:22 AM Thread Starter
Quoted: 11 Post(s)
Garage
I cleaned those multiple times thinking it was it. I found the problem though. The fpr that was in the canister was for a returnline setup. So basically my car had endless amounts of fuel pressure. I swapped the regulator out for a stock one and it fixed all my issues, afrs, stumbling, decel, starting up after sitting.
HybridKid likes this.
04 srt4
post #11 of 12 (permalink) Old 04-24-2019, 08:46 AM
gump1114's Avatar
Quoted: 126 Post(s)
Garage
i'm pretty sure i saw those pictures in one of the facebook groups. Glad you got it figured out.
post #12 of 12 (permalink) Old 04-25-2019, 09:11 AM Thread Starter
Quoted: 11 Post(s)
Garage
Yeah you probably did. I wasn’t exactly for sure about the fpr, until I posted it and they confirmed.
04 srt4
User Tag List
Linear Mode Linear Mode
Similar Threads
Return of the 10 Second SRT-4.... rezin8 SRT-4 Discussion 229 03-30-2007 06:03 PM
Mustang owner gets screwed (Good Read) Gator General Car Discussion 15 08-05-2004 02:19 PM
Car Names Explained...add yours! LOL hemidakota General Car Discussion 5 08-03-2004 11:50 PM
Car dies right after starting. Possible electric. 4k on car DocWhiplash SRT Problems & Dealer Service 6 05-18-2004 03:48 PM
You might be a ricer if (and i am one but this is still funny lol) Snowmirage General Car Discussion 17 05-13-2004 05:58 AM
