Can I use other brands other than Mopar for the MTF on my SRT4? - Dodge SRT Forum
 3Likes
  • 2 Post By blackbird_R/T
  • 1 Post By dodgezdad
post #1 of 7 (permalink) Old 05-26-2019, 02:03 PM Thread Starter
New Member
Hamlet's Avatar
Quoted: 4 Post(s)
Hello so do you guys recommend me buying specifically Mopar ATF+4 for the gear oil on my Neon SRT4 or is any brand like STP or Castrol fine? Thanks. Also I know a lot of people get butthurted when you post stuff that's already been posted before so feel free to remove this if it's been posted before
Hamlet is offline
post #2 of 7 (permalink) Old 05-26-2019, 05:30 PM
SilverBullet's Avatar
Quoted: 12 Post(s)
Depending on what you've got in there. What year is your car? Mopar ATF+4 is a peace of mind for me...and at is says in the manual--recommended.
Not butthurt but too common of a question given the history. The topic has been discussed many times, which should help you.
https://www.srtforums.com/forums/f21...90-oil-547413/
https://www.srtforums.com/forums/f25...brands-638717/
https://www.srtforums.com/forums/f21...rt-4-a-324427/
https://www.srtforums.com/forums/f21...-1-atf-273913/
https://www.srtforums.com/forums/gtsearch.php?q=ATF%2B4
No car. Searching... Found it!
SilverBullet is offline
post #3 of 7 (permalink) Old 05-26-2019, 05:51 PM Thread Starter
New Member
Hamlet's Avatar
Quoted: 4 Post(s)
Hahaha I was just trolling. And yeah it's a 2005. My trans is probably gonna die soon as its making strange tapping noises when in gear at idle, and yeah before I get it diagnosed I wanna change the gear oil and hopefully that helps which it most likely wont. But yeah who knows I'm hoping it just needs a clutch. Also thanks for the links I'll check em out.
Hamlet is offline
post #4 of 7 (permalink) Old 05-30-2019, 12:41 PM
csx321's Avatar
Quoted: 33 Post(s)
Your strange tapping noises could be loose flywheel bolts. It's been known to happen on these cars.
'04 SRT4, '87 Shelby CSX, '89 Shelby CSX, couple of others
2006 One Lap of America LER Media Crew
2009 Midwest SRT Nationals Attendee
csx321 is offline
post #5 of 7 (permalink) Old 05-30-2019, 07:28 PM
blackbird_R/T's Avatar
Quoted: 127 Post(s)
If the clutch release components, i.e. release fork/lever, etc. are going bad they can also sometimes rattle but usually go away when you depress the clutch. If you're on a stock clutch the flex plate to crankshaft or flywheel to flex plate bolts can also cause tapping noise as mentioned.
As to the ATF+4, quick answer is that for it to be branded as ATF+4 it has to be licensed from Chrysler/FCA. There's only a couple major producers and a lot of them are the same fluid in a different bottle, so buy the cheapest one you can find. For example, the Walmart Super Tech ATF+4 should be an exact equivalent to a bottle with a Mopar label from the dealer.
HybridKid and dodgezdad like this.
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '92 Dodge Daytona IROC R/T
'91 Dodge Spirit R/T - '19 Pacifica Hybrid Limited - '14 CTS-V Wagon
'08 Cobalt SS Turbo - '14 Cruze Turbo Diesel - '02 SVT Focus (S/C)
'04 SVT Focus (EAP) - '07 Ram 1500 - '81 & '85 Chevy Citation X-11
'90 Pontiac Turbo Gran Prix (ASC/McLaren) - '93 Olds Achieva SCX W41
Last edited by blackbird_R/T; 06-01-2019 at 10:48 PM. Reason: speeling/woording errorz
blackbird_R/T is offline
post #6 of 7 (permalink) Old 05-31-2019, 02:57 AM
Quoted: 155 Post(s)
Garage
I use valvoline synchromesh; used to use ATF but found something much better.
go ahead...change yours too now; again
lVlemphizStylez is offline
post #7 of 7 (permalink) Old 06-24-2019, 05:26 AM
dodgezdad's Avatar
Quoted: 4 Post(s)
With 216 thousand miles on my SRT I have used ATF-4 with FM, Amsoil MTF and Pennzoil Synchromesh....Pennzoil has been in for over 120,000 miles and with no problems with smoother shifts especially on cold mornings. My car has ball bearing bushings in the shifter cables and solid bushings at the Hurst shifter........I had to the replace the third gear syncho at 90,000 miles. I also replaced the snap ring and added a third gear extender at the same time..........I like the Hurst shifter because it has a stop so you don't stretch your shifter cable..........
HybridKid likes this.
dodgezdad is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
BREAKING NEWS! MOPAR STAGE 1 TURBO UPGRADE [email protected] Official Mopar News 366 08-01-2007 05:13 PM
NEW PICS OF MODIFIED MOPAR SRT4!!! NJ StreetRacing SRT-4 Discussion 22 06-27-2005 08:40 AM
MOPAR srt4 Sighting!!! esrt SRT-4 Discussion 10 06-08-2003 07:10 PM
MOPAR SRT4 Breaks FWD Records at Gainesville!! [email protected] SRT-4 Discussion 20 05-21-2003 04:58 PM
