Trying out the cheapest coil over on ebay - Dodge SRT Forum
post #1 of 3 (permalink) Old 05-17-2019, 06:21 PM Thread Starter
Quoted: 198 Post(s)
i found them on allibaba but ended up purchasing through ebay for $240 shipped (search: srt4 coilover, sort low to high)
<yes i could have BC'd for $1500 but why>
installed the rears today.. sunday i'll do the fronts..
couple of pointers
if the bottom of the tube (black) is flush with the bottom (orange) is the stock height
turning the bottom ~12 full turns equals 1", i went 8 turns in the rear, 3/4, since i run stock rear tires/rims
my car has 245k on it..
first 3 swaps were mopar
original springs, stock size tires.. sites 26" to the rear wheel well and 26.5" to the front
suggest
-removing the bottom and coating with grease so they don't lock up
-if the bottom of the tube is flush with the bottom mount its ride height
-i think all struts should have dust covers to prevent grit eating the seal, these ebay specials didn't come with a cover so i "getto'd" zip tied 4" abs drainage tubing.. yes its getto.. but i had it laying around
-you need to use a step drill bit (2 steps) on the the body for the strut top missing bolt (m8 30mm) for it to align
stock srt4 are 170#(f) and 125# (r), i think tein s are 200#
while the ebay listing says 8k spring rate, ali says 7k, mine have 8k printed on them
700 lb/in = 12.5 kg/mm
650 lb/in = 11.6 kg/mm
600 lb/in = 10.7 kg/mm
550 lb/in = 9.8 kg/mm
500 lb/in = 8.9 kg/mm
450 lb/in = 8 kg/mm
400 lb/in = 7.1 kg/mm
350 lb/in = 6.2 kg/mm
300 lb/in = 5.3 kg/mm
250 lb/in = 4.5 kg/mm
images don't seem to work
https://s1007.photobucket.com/user/n...=1558138147139
https://s1007.photobucket.com/user/n...=1558139476633
https://s1007.photobucket.com/user/n...=1558139942140
405hp, 450tq
https://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline
post #2 of 3 (permalink) Old 05-17-2019, 11:09 PM
T4EaterJonny's Avatar
Quoted: 432 Post(s)
Garage
BC are horrible. I cant imagine much worse to be honest. I used to have my spring rates in my signature...
I run BC coilovers revalved and respeung by Feal.
I think its 390lbs in the front and 330 in the rear. Good rotation. Very loose. I’m also running toe out all around.
2005 Big wheel stage 3, E85, BC rods, JE pistons stock 8:1 .020 over, BS delete, Sways & STbraces, coilovers valved by Feal, diy NACHO solid control arms.
2004 C5Z06
94 XR600R
Have you driven an SRT-4?... Lately?
T4EaterJonny is offline
post #3 of 3 (permalink) Old 05-18-2019, 09:42 AM
Quoted: 84 Post(s)
I love my BC's. Run them on my current SRT-4 and ran them on a previous SRT-4. Only issue I had was the locking sleeves locking up due to not using antiseize on the threads and driving the car in bad midwest winter weather.
Photobucket sucks. Just use imgur.com
Okay I saw the pictures. I really hope they hold up well man. They look like crap no offense haha. I personally would never cheap out on suspension stuff. But if they hold up over time being all modified and all more power to you on saving some coin.
05 PW1 SRT-4
AGP 50 trim and supporting mods
s3*ps2 is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
Please help goin crazy lol Johnny1991srt4 SRT-4 New Owner/Member Welcome Section 5 09-24-2018 10:46 AM
My new, personal quest...(eBay scams) castrol General Car Discussion 15 05-24-2004 04:22 PM
Fatmat??? SilverBullet General Car Discussion 4 04-03-2004 11:41 AM
new coil springs on ebay? madneon Visual/Body Modifications 0 09-09-2003 02:04 PM
