replaced axle seal an still leaking. PLEASE help. - Dodge SRT Forum
post #1 of 5 (permalink) Old 08-13-2013, 04:35 PM Thread Starter
New Member
Quoted: 1 Post(s)
i had transmission fluid leaking from the passengers side axle seal. I replaced the seal with a brand new oem one from dodge an its still leaking. I crawled under the car to inspect it an its looks like its coming from the inner part of the seal where the intermediate shaft goes into the transmission. anyone know what could possibly cause this? any help its appreciated. thanks
srtmanty is offline
post #2 of 5 (permalink) Old 08-18-2013, 09:04 AM
New Member
JAMobile760's Avatar
Quoted: 0 Post(s)
When you pulled the old seal did you inspect the surface that the seal presses into? If its not a problem with the seal it may be that your cv axle may have a little play where it clips in to the diff allowing the fluid to leak out.
JAMobile760 is offline
post #3 of 5 (permalink) Old 08-22-2013, 11:45 AM
New Member
srt4jdmkiller's Avatar
Quoted: 0 Post(s)
Replace your axle on that side. The surface of the old axle isnt sitting flush with the new seal. This happened to me and fixed the leak.
E85 Performance tune 🌽
"I'm like the Dodge dealership, I got a lot of challengers."
srt4jdmkiller is offline
post #4 of 5 (permalink) Old 08-22-2013, 11:37 PM
CrkZ1207's Avatar
Quoted: 1 Post(s)
Garage
Why is that? Does the outer shaft push in the intermediate shaft more?? I currently have a reman shaft from autozone. I've changed out the seal 3 times already and it's still leaking... Probably best to get one from Mopar....
CrkZ1207 is offline
post #5 of 5 (permalink) Old 08-23-2013, 12:47 AM
New Member
Quoted: 0 Post(s)
Best to get quality oem parts. That seal needs to be installed real carefully.
Those reman axles are decent, but try to get an oem one to avoid leaks.
Here's where I got mine. The high price was worth the peace of mind in the end.
Driveline - Mopar OEM Axles 03-05 Neon SRT4
User Tag List
Linear Mode Linear Mode
