Damage to steering rack? - Dodge SRT Forum
 1Likes
  • 1 Post By blackbird_R/T
post #1 of 5 (permalink) Old 05-17-2019, 07:12 AM Thread Starter
Quoted: 0 Post(s)
Last night on the way home I noticed that my power steering was not working (hard to turn and noise when turning left or right from intersection). Traveled about 30 miles. In the morning checked the reservoir level and it was empty. Taking it to the auto garage this weekend. I did not hit anything, no potholes to jar anything loose.
This is a 2003. Mods done are a LSD done about 10 years ago and PT GT turbo knuckles installed and MOPAR Stage 1 lower springs, 16x7 wheels with 225/50/16 tires. This was done last fall when I got the car running after setting about 4 years.
Did I damage the steering rack by driving 30 miles with no fluid. If so any recommendations on steering rack replacements?
Postal is offline
post #2 of 5 (permalink) Old 05-17-2019, 07:46 AM
Gizmodo's Avatar
Quoted: 95 Post(s)
After you find the leak, put some ATF in and test it. You'll have to bleed the system by turning lock to lock over and over again. I would lift the front end for that part.
Gizmodo is offline
post #3 of 5 (permalink) Old 05-19-2019, 12:37 AM
blackbird_R/T's Avatar
Quoted: 127 Post(s)
The rack should be fine from running empty. It does lubricate the internals of the rack but even if not pressurize you'd probably still have some residual fluid in the housing.
The stock power steering pumps tend to get noisy on the 2.4L, especially if you haven't regularly changed the ATF+4 fluid. Running a power steering pump dry can cause bearing and internal wear but your first course of action is to find where the fluid went. Maybe the reservoir cracked. Maybe a line rusted or broke. Maybe the rack is leaking internally out the tie rod boots.
Get that fixed, refill the system and see if there's any noise or problems. If there's been some noise/whine and you think it might be a little worse after fixing the source of the leak, I'd consider using a syringe or something to occasionally pull a little ATF+4 fluid out of the reservoir to make sure there's no metal or other debris.
fixit likes this.
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '92 Dodge Daytona IROC R/T
'91 Dodge Spirit R/T - '19 Pacifica Hybrid Limited - '14 CTS-V Wagon
'08 Cobalt SS Turbo - '14 Cruze Turbo Diesel - '02 SVT Focus (S/C)
'04 SVT Focus (EAP) - '07 Ram 1500 - '81 & '85 Chevy Citation X-11
'90 Pontiac Turbo Gran Prix (ASC/McLaren) - '93 Olds Achieva SCX W41
blackbird_R/T is offline
post #4 of 5 (permalink) Old 05-20-2019, 09:36 AM
Quoted: 198 Post(s)
i'd guess its just the belt popped off (need to replace tensioner) or its just low on fluid..
405hp, 450tq
https://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline
post #5 of 5 (permalink) Old 05-20-2019, 10:51 AM Thread Starter
Quoted: 0 Post(s)
Shop called. The pressure line had a pinhole. Considering the lines are original (16 years) guess it's time to replace them.
Thanks all for the help.
Postal is offline
User Tag List
Linear Mode Linear Mode
Similar Threads
Power steering leak BrothaGrimm Drivetrain Discussion 7 01-08-2019 08:42 AM
Neon Steering Rack - Anyone tried it? GetMeSRT! Performance Modifications 10 12-14-2005 12:34 AM
Steering wheel noise.. middlemiss SRT Problems & Dealer Service 1 07-17-2004 09:07 AM
steering rack thestereogod SRT Problems & Dealer Service 4 04-16-2004 02:34 PM
SRT Puked Power Steering Fluid + Nasty Tow Story monkeyboy SRT Problems & Dealer Service 38 01-09-2004 04:44 PM
