try checking to see if you throw p0633 code. turn you key to the on position then off. do this 3 times and the code will appear in the odometer. fyi...if you don't see anything you could still have S1. it is possible to clear that code from a scan tool or code scrubber.
Mods:
S2 w/o, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Mopar TB Exhaust (cat-back+cat-delete), Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV,4306 NGKs, JMB catchcan, Pwerks grounding kit, PTP check valve
