Will the 2-Step limiter come on during WOT Shifting?
I'm getting close to installing my MSD DIS-2 & I was thinking. Will the 2 step interfere with the WOT Shifting?
Think about it, on the launch the clutch is engaged & the throttle is floored. During a WOT shift the clutch is engagued & the throttle is floored. I'd hate to hit the 2 step limited when trying to shift?
Is there a way to make the 2 step only work in 1st gear?
John Ruckman
- Stage 3 W/ Toys
- AGP WGA, Race FMIC & 3" Intake
- Custom Magnaflow Exhaust & O2
- Eibach Prokit
- B-Woody Traction Bars
- ND Performance Traction Control System See My Ride Here
you should have a momentary contact switch to activate the 2 step.although it may help you if it did work that way.cutting ignition with the dis between shifts would only help the input shaft to slow down enough to make a smoother shift
Email: Jay@N2MB.com
take a moment today to reflect on what happened on 11 september 2001...
Ohh, So I have to run a switch or button from the engine bay to the cockpit somewhere. Make it so when I push the button it connects the circuit (blue wire) to activate the 2 step. I hadn't thought of doing that.
Basically I could just push & hold it down to activate the 2 step, then when WOT shifting it won't activate as long as I don't push the button. is that correct?
yes that is how i have done it, my swith was on the front of my center councel, when you push the button it will activate the 2-step when you let off the button you wont have any issues wot shifting. let me know if you have any questions john i might be able to help.
New custom s372r setup:
750hp, 560tq...26-27psi not spray
through dcr auto trans..
****Second street Srt-4 in the 9's 9.95@143****
old setup:
742hp, 650tq...35psi&90shot of spray from a 37r through a dcr auto trans..
**worlds Fastest Dot tire srt-4**
10.51@144
So do you have to reach up & turn it off after you launch?
i used a momentary switch where when you push the buttom it is on the second you let off the button it is off, would be best if you could get a shify knob that had a push button arleady in it. i dont know if you need to have two hands on the wheel to launch i never did.
The horn is not too bad of an idea. I really like to have my left hand on the wheel & the other on the shifter when I launch. Trying to push down the horn would be about the same as holding up the e-brake in my book.
I wonder if there's a way to use the wireless greddy profec hi/lo boost switch to do the same. I don't really use it right now? I can easily hold it down with one hand on the wheel too!
This way I wouldn't have to remove the steering wheel. I'm sure the wires that go from the wireless receiver to the back of the EBC unit could be wired into the DIS-2? Heck what do I know, I'm not the greatest with electronics Anybody else
