Quote: Originally Posted by srtD-dog4
at wot im still around 14, i have a 50 trim with 750 injecters, fuel pump, stage 1 ecu, never even seen it go down as low as 13. im running either 15 or 20 pounds of boost either way its the same. i also have the safc2 but dont know how to use it, a shop tuned it about a year ago but may have messed it up, not to thrilled about their work
something must be wrong. If your at 14 at wot.. your motor should have blown on pump gas..what wb do u have... if aem u dont have to calb. it but the lm1 you have to... to calb it just turn the car off unscrew the sensor off the pipe and turn the key to the on. hit calb. on the lm1 and it should read 14.7ish then plug it back in. if ur at 14 to 15 at idle then your wb should be workin right.
i dont know what wb u have. well let me know..
you have 750 injectors and ur car is lean.(as the wb says) are u gettin ping(sounds like rocks on the windshield at wot)
