Quote: Originally Posted by
rasp
I have the LC-1 and haven't had this issue. Mine is mounted most likely where yours is, on the incline of the downpipe. I've driven my car in the ran and have had no problems.
Yea I have it on the incline part of the pipe at around the 9:30/10:00 position if you were to look up the pipe
rasp
Check all connections. Any chance you can have someone watch the gauge and you wiggle the O2 sensor wiring to see if it changes? Also check the adapter that houses all the LC-1's electronics and make sure that looks OK. I have mine zip-tied to a brace on the motor to keep it from bouncing around.
I can try and have someone look but the LC-1's unit is INSIDE THE CAR behind my headunit / stereo so it's away from the outdoor elements.
rasp
Perhaps you should recalibrate it again and see if that fixes the problem?
I could...but this problem I had from day 1 (I calibrated it when I first installed it)
duster360
I'll ask this again because you obvioasly failed to grasp its importance:
Does the A/F read fine on the PC?????
LOL...I don't have a laptop with a serial connection so I can't do that.
Plus wouldn't I have to wait until it rains again before this comes up. I mean I could always wire the unit into my Aerometer scan gauge and see if it outputs the same problem.
