I installed an Innovate Wideband LC-1 and gauge 5 days ago. It worked fine for 2 days, reading @ 14.6 across the board. Today I turned on the car and the needle went through it's little test phase as it does during each startup, but pegged at 18. I know the car is not running this lean. The needle is acting very randomly, for example when I GENTLY tap the gas at a stop light, it will go all the way to 1 and back to 18. Any suggestions? Thanks.
Well theres your problem buddy,go to the paint shop and woop some ass.
Aside from kicking ass lol, any idea what the problems could be? I've heard a possible exhaust leak so far... other than that I'm stuck as to what to look for.
Where are your grounds located for the wideband? Should be 4 of them...if you have them all in separate spots that's a bad idea. Make sure your grounds are all tied to one terminal, and on a GOOD ground. Lots of guys use bad grounding locations for this. I used a bolt on the head and never had an issue after that. Mine used to do the same thing yours is doing.
O4 PT Cruiser non GT
Stock b****es, come get me
I'm not sure. I cut the wires that were the ground for my narrowband (installed when I purchased the vehicle) and soldered all the grounds from the wideband to this ground. I will look into it though. Thanks for the tip.
