Old 12-21-2004, 11:59 AM   #1 (permalink)
FrontMounted's Avatar
Member Number: 9995
Trader Rating: (10)
Exclamation wideband and e-01 conversion problem
I hooked up my zeitronix wideband to display on my e-01. The volts are correct because I am getting the correct voltage 2.5 for my car per zeitronix's conversion (2.5v=14.7A/F) at idle so it's hooked up correctly. But, when I put in the voltage conversions on the e-01, the A/F ratio is off. It will read 18.5 A/F ratio at idle instead of 14.7, and 14.7 is correct for my car and that's what 2.5 volts is on the zt-2 conversion table. The e-01 has a conversion for the highest and lowest A/F and highest and lowest volts. It messed up when I put in the highest and lowest sets of data that come on the ZT-2 conversion table. Is there a certain set of data I should use for the e-01 to display correctly? I can only pick from two. Someone has to be also using this wideband along with an E-01.
I mean I know what is going on but has anyone made it work?
Ok the highest and lowest volts by zeitronix conversion are 3.27v = 21.2 A/F and .15v = 9.7A/F and the median of those volts is 1.56v which equals 12.1A/F by zeitronix. But, obviously, 12.1 is not the median of 21.2 and 9.7 and that's the problem. The e-01 converts my 2.5v idle to 18.8A/F because there is no pattern of the zeitronix conversion table.
Another example:
By zeitronix .15v = 9.7A/F and .31v = 9.9A/F So, every .16v+ means .2+ A/F
But, 2.8v = 16.9A/F and 2.96v = 18.5A/F
The volts still only went up .16 but the A/F jumped 1.6 instead of only .2 like the other one.
I hope this all made sense. Thanks.
"straight clownin" This is not Photoshop
It's for someone considering an Acura RSX, but actually wants some power --Road & Track
FrontMounted is offline   Reply With Quote
Old 12-21-2004, 12:18 PM   #2 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Another example:
this is the main reason why using a 0-5v linear output is easy to set up. the LM1 has a linear output as does the PLX units.
i have the LM-1 set up to output 0-5v (10.00-19.99 afr) on the E01 i have the same conversions made.
on ours 2.35v =14.7:1
so on your E01 you have the following:
0 volts --- 9.70 afr
3.5 volts -- 21.00 afr
i think the problem you are running into is that 3.5 volts does not equal 21:1 afr. 3.25v seems more like 21:1 afr, according to the diagram below.
have you tried setting it up on the E01 to read:
0 volts-- 9.50 afr
5volts -- 21.0 afr?
Old 12-21-2004, 12:25 PM   #3 (permalink)
Member Number: 11555
man, that's going to suck, the output is not linear.
ToFu is offline   Reply With Quote
Old 12-21-2004, 12:28 PM   #4 (permalink)
NIVO88T's Avatar
Member Number: 1109
looking at the zeitronix site i see this:
Analog Wideband Output 0 - 5V , under ouput range. so maybe it is a analog linear output (0-5v)
have you measured the output wire to see if it displays 5.00 volts while it's free air.
Old 12-21-2004, 05:19 PM   #5 (permalink)
Member Number: 9995
Trader Rating: (10)
It's about 3.30v with the car off showing 21.3 A/F. When I was driving, the A/F e-01 peak memory thing shows 31.6 A/F so that would mean that it probably did show somewhere around 5 volts then. I guess that I will try just entering 0-5v and see what happens. My car is still running on stock fuel everything and stock 03 injectors. I have not done any fuel mods until I get this wideband thing straightened out.
Old 12-21-2004, 05:24 PM   #6 (permalink)
Member Number: 13362
Trader Rating: (109)
Not trying to hijack this thread but I need some help to , I have the LM-1 hooked up to mine , on the e-o1 screen I have the volt at 2.35-5.00 & conversion at 0-0 . What do I need to put in for the conversion ?
2.4TURBOMAN is offline   Reply With Quote
Old 12-21-2004, 05:28 PM   #7 (permalink)
Member Number: 9995
Trader Rating: (10)
Nivo said this earlier:
So that means you put 0 and 5 in the volts blanks and 10.00 and 19.99 in the blanks below that.
Old 12-21-2004, 05:32 PM   #8 (permalink)
Thanks.
Old 12-21-2004, 05:44 PM   #9 (permalink)
NIVO88T's Avatar
Member Number: 1109
Thanks.
also, you need to reconfigure the outputs on the lm1 to read afr and 0v=10.00:1 and 5v=19.99:1.
you will need the lm1 software to do this and a desktop or laptop.
Old 12-21-2004, 11:23 PM   #10 (permalink)
Member Number: 12706
Having the same problem with my zeitronix. I'm just going to take a voltage in the 9.x range and use the 2.5v at 14.7 and see how close it is.
SRT42B is offline   Reply With Quote
Old 12-22-2004, 03:45 AM   #11 (permalink)
Member Number: 9995
Trader Rating: (10)
Ok, I just got an email back from zeitronix. They said to put in the rich side of the conversion and then up to 14.7 like what you are saying.
Page generated in 0.24334 seconds with 14 queries
