Old 07-19-2004, 06:58 PM   #1 (permalink)
Mike V.'s Avatar
Member Number: 9234
Default Why is everyone using SAFCs??????
SAFC's were not designed for turbocharged vehicles.
SAFC's are not boost dependent. They can not adequently nor correctly control the fuel of a turbo charged vehicle. They are not accurate through boost in all five gears because fuel load changes between gears and throttle response.
SAFC's are a bandaid and are not the best one at that.
You want to trust your turbo motor to a bandaid fix? Have fun!
Mike V.
BSME
1995 Plymouth ACR Coupe
1997 Dodge Neon Sport Coupe
Mike V. is offline   Reply With Quote
Old 07-19-2004, 07:00 PM   #2 (permalink)
Member Number: 3499
mine is AWESOME! best mod by far.
myfault is offline   Reply With Quote
Old 07-19-2004, 07:05 PM   #3 (permalink)
MySRTfriesrice's Avatar
Member Number: 2515
Just curious, what brought you to this conclusion? Judging by your sig, you are not highly modded, so this isn't exactly the final word from God. How have you acquired the knowledge to say with such absolute fact that they are, as you say, a "bandaid"?
2007 Force Protection JERRV.
6x6. 44,000lbs. 860 lbft of Torque.
And A/C that quits working. Constantly.
MySRTfriesrice is offline   Reply With Quote
Old 07-19-2004, 07:31 PM   #4 (permalink)
SRTforums Oldtimer 4
Hades's Avatar
Member Number: 6873
I see that you have come to this conclusion based on extensive research . Hmm.. let me see , where to begin correcting your misinformation. The way that people run there Super AFC's on the SRT-4 is by using the map signal as a refference point not the throttle signal. Therefore the amount of fuel that is being taken out is boost dependent. Next matter of business; you say they can not adquedetly , nor correctly control the fuel. The super AFC was not designed to directly control fuel, it was designed to modify certain signals being sent to the car's ECU. The ECU then makes decisions based on all of it's information, including the signals that are modified by the Super AFC. Ultimately, the ecu still has a large degree of control. I ran a super AFC on my car for about 2 months, until I switched to the bigger fuel injectors. The entire time that I had it, it worked great and I had no problem mantaining correct A/F's. The 390 HP that i put down was while using it.
[FONT=verdana 2004 E-Blue
Stg 2 ECU
AGP 50 trim T3/T4 turbo
AGP 3" CAI
RC 750CC Injec.
Turbonetics WG
Walbro 255 FP
Greddy Type S BOV
Greddy E-manage
Greddy E-01 BC
Greddy TT
E.D hardpipe kit
Spec STG 3 clutch
Mopar STS w/jlm bushings
Clear side mkers.
Custom 3" turbo back exhaust
Under drive pulley
JLM Motor mounts
Hades is offline   Reply With Quote
Old 07-19-2004, 07:50 PM   #5 (permalink)
Ghost's Avatar
Member Number: 2060
Im going to watch this thread. I am looking to get the safc II and this could be on argument.
Ghost is offline   Reply With Quote
Old 07-19-2004, 07:51 PM   #6 (permalink)
IWantAn04's Avatar
Member Number: 3377
now that you have the bigger injectors what do you use?
IWantAn04 is offline   Reply With Quote
Old 07-19-2004, 08:32 PM   #7 (permalink)
Hades's Avatar
Member Number: 6873
Sorry I didn't qualify that statement. I switched from the SAFC- II to the e-manage and e-01 system because the RC-750 injectors are too big to run with the super AFC-II from what I have found. I went with the Greddy E-manage system. I have additional injector drivers that I am able to add fuel with and I can still clamp the map signal at what ever voltage I desire.
Old 07-19-2004, 09:15 PM   #8 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
if you monitor the boost level instead of throttle position i believe you will be ok using a SAFC as that will compensate for airflow characteristics of a turbo'd car.
C
Damn it, Have a nice day...
11.9@121 Bithlo
SRT-4 Neon is offline   Reply With Quote
Old 07-19-2004, 09:23 PM   #9 (permalink)
pap
SRToc Member
pap's Avatar
Member Number: 1015
hmmm. interesting. I guess the fact that the AFC was in my car for over a year with a near perfect fuel curve running 290hp on the stock turbo had nothing to do with the AFC then. I guess perfect tire pressure had something to do with that.
I do agree with one thing, it is a decent band aid but not as flexable as some other piggy backs such as the e-o1 and smt-6. These other units allow for some more tunability with additional points of adjustment.
Pap
pap is offline   Reply With Quote
Old 07-19-2004, 10:40 PM   #10 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
I've been running the SAFC II for a couple of mos. now with no problems to speak of...got to thank PAP for all his help in using and setup of the SAFC!!
RoostBoost is offline   Reply With Quote
Old 07-19-2004, 10:52 PM   #11 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
yeah i have to say i am not a fan of the SAFC, but i've seen some high powered SRT's running it successfully.
C
Old 07-20-2004, 07:49 AM   #12 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Mike V.
So what are they for?
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 07-20-2004, 12:55 PM   #13 (permalink)
SRT4shizzle's Avatar
Member Number: 3794
Mike V.
Thats funny weve been using the AFC for the last few months to tune out some fuel curves. Not a problem so far, where are you getting your misinformation?
Also when have you had expirience with the S-AFC?
Founder of the
DNC - Daytona Neon Crew - DNC
SRT4shizzle is offline   Reply With Quote
Old 07-20-2004, 10:58 PM   #14 (permalink)
Nysbadmk8's Avatar
Member Number: 12330
I do have to agree that the SAFC isnt ideal for the Srt-4 app. but it has worked well for some members... But im going to go the e-manage way.
2004 E-Blue Srt-4
2003 Mustang Cobra
2003 Millenium Yellow Corvette
2001 Ford F-350
2000 Jeep Cherokee
34 cylinders 2080 Rwhp 2230 rwtq and One big fat insurence bill.
Nysbadmk8 is offline   Reply With Quote
Old 07-21-2004, 08:03 AM   #15 (permalink)
Member Number: 3794
Im going with the Emanage as well, but Ive seen this unit work flawlessly when properly tuned.
Josh
