Quote: Originally Posted by Fst Blk GTi
u can do map vs rpm on the emanage
you can do map vs rpm in the add. injector map. Which allows you to add duty cycle to the injectors, not take away duty cycle. What if I need to remove fuel, I have to use TPS vs RPM in the airflow adj map. Unless theres some setting im missing you can inform me of.
