Old 08-19-2004, 05:05 PM   #1 (permalink)
Member Number: 12058
Default Why do I want e-manage instead of SAFC?
Guys, I will have an AGP GT40 kit installed very soon. I have done some searching here to find my answer, but I can't really find the specific info I am looking for. I know the emanage system is a piggy-back system that allows much more control over the engine than the APEX SAFC allows.
Can someone tell me what I will specifically miss out on by using a SAFC instead of an emanage setup? Will I not be able to fully tune the fuel curve for different RPM ranges? Why do I need a MAP clamp? What problems will I face with this turbo and an SAFC that I could correct with an emanage setup?
Thanks
2004 SRT-4 (EB)
AGP GT-40, etc. - Untuned
essbase is offline   Reply With Quote
Old 08-19-2004, 06:40 PM   #2 (permalink)
FrontMounted's Avatar
Member Number: 9995
Trader Rating: (10)
I was in your dilemma a few weeks ago. I was set on getting the SAFC. I now have the emanage and an E-01 in boxes in my room.
This is what I have been told:
The emanage is practically the same price.
There is alot more adjustment on the emanage. Some people have maxed out the SAFC's ability to add fuel.
The emanage pretty much overrides the computer. You have more control. It works well with the E-01 and a wideband. It can graph out A/F ratios on the E-01 with a wideband (LM-1 for example).
Most people getting 400+ hp are using emanage.
Simply put, I have just heard all this and that it's just better. Hope that helps.
It may be a little more complicating but I like to figure things out.
"straight clownin" This is not Photoshop
It's for someone considering an Acura RSX, but actually wants some power --Road & Track
FrontMounted is offline   Reply With Quote
Old 08-19-2004, 07:06 PM   #3 (permalink)
JjkatxSRT4's Avatar
Member Number: 9016
another question is there any purpose on running profec b with e0-1 if you want to utalize the e manage, or should i pick up those last two an then would the profec b unusful anymore?
HP #'s coming soon!
JjkatxSRT4 is offline   Reply With Quote
Old 08-19-2004, 07:46 PM   #4 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
the profec e01/emanage combo is nice as it deletes the need for a laptop.
I have this set up and love it...I have seen the sAFC and they are nice, with a few other upgrades (injectors) its great for fuel management.
The emanage is nice in that you can control fuel by reading boost (MAP voltage) and Throttle position. It includes a MAP clamp that RPM adjustable. You can control injector duty cycles. Lots of stuff.
C
Damn it, Have a nice day...
11.9@121 Bithlo
SRT-4 Neon is offline   Reply With Quote
Old 08-20-2004, 12:02 AM   #5 (permalink)
I8URVR6's Avatar
Member Number: 8924
The e-01 IS a boost controller so you don't need a profec-B.
The emanage has far more options than the s-afc does, as well as the ability to handle larger injectors that 650cc.
The e-01 can display 3 gauges at once, can boost based on rpm, display realtime info like a/f and egt simultaneously.
it can clamp your map sensor!
bla bla bla, it's just a better combo. thats why it's on my way from exhaust depot right now :-D
I8URVR6 is offline   Reply With Quote
Old 08-20-2004, 12:45 AM   #6 (permalink)
SlowV6's Avatar
Member Number: 1203
Emanage clamps the map.
Not the e01.
SlowV6 is offline   Reply With Quote
Old 08-20-2004, 01:49 AM   #7 (permalink)
birddog's Avatar
Member Number: 12743
I'm in the same situation as essbase. Sounds like the E-manage is the way to go! Anymore info of the pros and cons of both systems would be nice.
birddog is offline   Reply With Quote
Old 08-20-2004, 02:26 AM   #8 (permalink)
dangerously_cool's Avatar
Member Number: 1577
Then you can give ED your money!!!! Yay!
Gone to those big twisties in the sky.
dangerously_cool is offline   Reply With Quote
Old 08-20-2004, 02:45 AM   #9 (permalink)
I8URVR6's Avatar
Member Number: 8924
yeah that's what I meant, emanage clamps the map.
With the Profec e-01 it attatches via a cable to the emanage, allowing you to program and adjust the emanage via the e-01, no need for a laptop to interface.
Old 08-20-2004, 02:48 AM   #10 (permalink)
JjkatxSRT4's Avatar
Member Number: 9016
awesome when i upgrade to a new turbo an fuel requirements down the road ill use the e01 an emangement damn I cant wait for this stuff now, then ill have to rid the profec b.. Does ne have this combo on stock turbo how much does it help cause I noticed profec b boost runs kind of really unsmooth. Maybe its alot of backpressure I dunno sometimes it does great tho I worry in Wot running around 15 psi spiking down from 18 but tommorow im going to the dyno and gonna get some pulls an see if they can tune it a bit.
TIRED AS FUCK who cares^<
Old 08-20-2004, 02:52 AM   #11 (permalink)
I8URVR6's Avatar
Member Number: 8924
dude, paragraphs please. at least seperate that jumble of a thought out a bit
I saw someone with the e-01/emanage setup put down 297whp and over 300lb-ft
Old 08-20-2004, 02:59 AM   #12 (permalink)
I8URVR6's Avatar
Member Number: 8924
http://srtforums.com/forums/showthread.php?t=74354
Old 08-20-2004, 03:02 AM   #13 (permalink)
srt4hokie's Avatar
Member Number: 1615
Trader Rating: (12)
Because Hector says so, what else do you need?
I should be considered the best seller on her as my customer service rivals every vender on here, well except AGP and Hector and I would say I'm as good as them Especially when you consider people come to me for help when Hector terns them away since they did not buy there stuff from them.
Did I mention I don’t even own a srt any more...
srt4hokie is offline   Reply With Quote
Old 08-20-2004, 06:31 AM   #14 (permalink)
Ray00's Avatar
Member Number: 1230
Trader Rating: (52)
i have the e01 and emanage combo. its awsome and simple to use, once you know how to that is. any way my car makes great power!!!! and i know im making great power when stuff on my car starts breaking anyway again it is a great piece.
oh btw the best part of the emanage is the vtec controller. this has been the most usefull for me.
Ray00 is offline   Reply With Quote
Old 08-20-2004, 08:14 AM   #15 (permalink)
Member Number: 180
well, with the s-afc you have to reprogram and tweak your fuel curve. with the emanage you tell it your injector sizes and it does the fuel curve for you saving you a lot of time. then when its time to boost all you really have to deal with is adding injector duty cycle. get a WB make a run, watch your AFR stop, figure where to add duty, program, repeat.
NeonWaSp is offline   Reply With Quote
