Old 06-29-2004, 05:45 PM   #1 (permalink)
Member Number: 12931
Default where is the tach wire?
I am trying to hook up a shift light but i nee to know where i can splice into the tach wire. Any help would be great.
syclone738 is offline   Reply With Quote
Old 06-29-2004, 05:51 PM   #2 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (49)
you need a tach adapter. you cant just splice in. do a search for the part number.
Old 06-29-2004, 05:52 PM   #3 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (98)
Look in my section, I hvae hte low down for you on there. Tach driver.
Exhaust Depot is offline   Reply With Quote
Old 06-29-2004, 05:53 PM   #4 (permalink)
SRToc Member
Bin4ry's Avatar
Member Number: 2282
Trader Rating: (12)
http://www.srtforums.com/forums/show...238#post868238
Bin4ry is offline   Reply With Quote
Old 06-29-2004, 05:53 PM   #5 (permalink)
SRToc Member
Bin4ry's Avatar
Member Number: 2282
Trader Rating: (12)
oh and:
MSD Tach Adaptor Model 8913
Old 06-29-2004, 05:55 PM   #6 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
your going to need a tach adapter as mentioned, MSD part number 2913.
and tap into this wire:
Green wire
Pic courtesy of Exhaust Depot. for all your exhaust and intercooler needs, theres only one exhaust depot...we deliver for you!
Old 06-29-2004, 05:57 PM   #7 (permalink)
NIVO88T's Avatar
Member Number: 1109
you guys beat me to it!
Old 06-29-2004, 06:27 PM   #8 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
don't you also need the pill module?
C
Damn it, Have a nice day...
11.9@121 Bithlo
SRT-4 Neon is offline   Reply With Quote
Old 06-29-2004, 06:45 PM   #9 (permalink)
Member Number: 143
Trader Rating: (98)
Pill modual?
Old 06-29-2004, 07:28 PM   #10 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
i think it depends on the shift light you get...but to use my MSD pen light with the tach driver i had to buy the pill module (aka RPM activated switch, MSD p/n 8950). I stick in various resistors that tell the shift light when to light up. I tried to go right from the tach driver and couldn't do it.
Just something to consider when selecting lights. I know both MSD and autolite make integrated switches in some of their lights as well. The autolite one is nice as the pills go into the front of the light so no need to go under the hood as I have to.
C
Old 07-01-2004, 04:04 PM   #11 (permalink)
Blue Rocket's Avatar
Member Number: 6027
Nivo, is it okay to use tap-in connectors? or should I solder the wires?
500 AWHP, 433.XX TQ., 95.XX dyno room temps
Best Trap: 12.2 @ 124 MPH
Best E/T 11.8 @ 120 MPH
Blue Rocket is offline   Reply With Quote
Old 07-01-2004, 04:21 PM   #12 (permalink)
SRToc Member
Bin4ry's Avatar
Member Number: 2282
Trader Rating: (12)
I dont think you can't tap it. The tach adaptor goes inline with that wire.
Old 07-01-2004, 04:22 PM   #13 (permalink)
SRToc Member
Bin4ry's Avatar
Member Number: 2282
Trader Rating: (12)
Quote: Originally Posted by Exhaust Depot
Cut greenwire with orange stripe on the coil. This is the VCC for the coil. Attach the red with green stripe TOWARDS the COIL. Attach the solid red wire towards the POWER DISTRIBUTION.
THe black is ground, I like to attach it tot he battery cable. THe grey is your tach signal.
You can tie wrap the unit to the hoses and vacuum lines on the side of the battery tray.
If you dont have a soldering iron, then you should not be purchasing this item.
Yo!
Old 07-02-2004, 08:02 AM   #14 (permalink)
Member Number: 6027
Quote: Originally Posted by Binary Poet
i'm kinda confused but I'll look at the MSD wire instruction diagram one more time
Old 07-02-2004, 05:40 PM   #15 (permalink)
NIVO88T's Avatar
Member Number: 1109
soldering is best, especially for critical components like ignition and the brain (PCM)
Page generated in 0.24388 seconds with 13 queries
