Old 06-17-2008, 11:43 AM   #1 (permalink)
Member Number: 63759
Default Where to install wideband o2 sensor?
I managed to get an AEM Wideband (controller and sensor) for $85...I would've been stupid to pass it up eh? Anyways, do you really have to make a new hole for the wideband's O2 sensor? I thought it would replace the one closer to your turbo
Old 06-17-2008, 12:27 PM   #2 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (21)
If you have any staged upgrades like S1-S3 then you can use the downstream 02 sensors bung and just ziptie the stock 02 sensor. You cannot disconnect the stock 02 sensor, but you can leave it plugged in and just tie it up and out of the way. If you still have a cat on your car, make sure the wideband is before the cat otherwise you'll get a false reading.
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 06-17-2008, 02:19 PM   #3 (permalink)
K...gotcha. What can I do if I have only S0?
Old 06-17-2008, 05:18 PM   #4 (permalink)
Trader Rating: (21)
I'd say honestly just spend 10-15 bucks and have a local shop weld a bung in for ya.
Old 06-23-2008, 12:37 PM   #5 (permalink)
jonnymopar's Avatar
Member Number: 44907
So if you don't have a catalytic converter, should a bung be welded rougly the same distance down the pipe as the original downstream sensor was?
Jon J.
2003 Neon SXT - MPG
1989 Daytona ES 2.4 - MPH
jonnymopar is offline   Reply With Quote
Old 06-23-2008, 01:03 PM   #6 (permalink)
Yesterday me and my friend took off my downpipe. Welded a nut onto the pipe (a hole as drilled obviously). Got it all setup and installed...working great. What should idle A/F be at? I'm bouncing inbetween 14.3 and 15.7?
Old 06-23-2008, 01:04 PM   #7 (permalink)
Trader Rating: (21)
Yes. I found it's a good idea just to have a location for the stock 02 sensors to go, then a 3rd one for your wideband. The wideband and the downstream 02 sensors will end up about 3-5" apart which is perfectly fine. Just make sure they are either at the 3 oclock or 6 oclock position on the pipe...if you put them too low you can have premature problems with your 02 sensors.
Old 06-26-2008, 03:57 AM   #8 (permalink)
lphooper03's Avatar
Member Number: 37050
Does anyone know the size thread for a o2 sensor? I got an open hole in my exhaust where a wideband used to be and i want to plug it up.
2003 Solar Yellow
Mods: AGP 50 Trim, 38mm Turbonetics WG, SAFC 2, Walbro 255, Centerforce Dual Friction, UEGO, DW 650cc Injectors, LED Tails, Fuel Pump Rewire, Perrin STS, QW IC, Mxp Turboback, Injen SRI, AGP UHP w/Greddy S BOV (T-Bolts), Blitz TT, 30/30 Boost, Drop Springs, Black Stripes.
Coming Soon:W/I, Cams, Portwork, Scan Guage
Waiting to be installed: N2MB WOT Box/2-step & Ported TB/Spacer
Old 06-26-2008, 12:43 PM   #9 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
18mm or M18x1.5
Google is a wonderful thing
Oh need a plug heres the cheapest one, didnt even have to know the threads
O2 Oxygen Sensor Ring Plug - Zinc Plated: O2PZ Verocious Motorsports
Project log pics
SpeedEuphoria is online now   Reply With Quote
Old 06-27-2008, 09:48 AM   #10 (permalink)
Plug it with a Wideband
» Search Used Cars
Page generated in 0.23831 seconds with 11 queries
