Old 12-04-2004, 09:44 AM   #1 (permalink)
Member Number: 8887
Default where to install egt?
well i see them installed on the manifold before the turbo in most cases but autometer says to install after the turbo so who should i go with? where are you guys putting them in the srt's?
highpsi is offline   Reply With Quote
Old 12-04-2004, 11:23 AM   #2 (permalink)
Member Number: 11814
Trader Rating: (109)
Not an expert on this.
Some people say that if the senor tip fails and breaks off it could do damage to the turbo if EGT probe placement allows this.
Others say that if sensor not placed properly you will not get a true/good EGT reading in order to tune with. Proper placement is close to the cyl head, and represents the EGT for all cyl's, so you should not put it in one indiv runner.
An option is to install the EGT probe in a place that will get good readings for tuning. make sure you can plug the hole if probe removed. Tune the car, and than remove and plug with correct fitting/cap/plug.
If you want, install the probe in manner which is safe for the turbo incase of probe failure, and accept that the readings are a little less than true and tuning to the limit using or relying on those readings could be risky.
If the EGT gauge is more for looks def place in location that is safer or less risky to turbo failure if EGT probe fails.
Again I'm not an expert and can be very wrong with this.
Old 12-04-2004, 01:35 PM   #3 (permalink)
NorwayGT's Avatar
Member Number: 15050
dumb question....what does EGT stand for?
1.9 60ft 12.9@106 266hp 333.5tq
S1, mbc, agp wga, 3 inch dump TB, ngk plugs, msd wires, boomba MM's, dynoworks tranny mount, hochkis springs, tokico illuminas, hotchkis sway bars, DC front/rear strut tower bars, mopar STS, booger shifter bushings, MBmotoring 16x7's, 225/45/16 kdw's
NorwayGT is online now   Reply With Quote
Old 12-04-2004, 01:42 PM   #4 (permalink)
LTLVIPR's Avatar
Member Number: 1394
exhaust gas temperature
SRToc Member #93
http:// forums . street racing technology . com
No money grubbing BS, just discussions, group buys, and more.
Quote: Originally Posted by New SRT owner
Why is that metal thingy in front bigger than mine?
Quote: Originally Posted by Blue04soon
Thats the intercooler. The faster you go, the bigger it grows!!!
LTLVIPR is offline   Reply With Quote
Old 12-06-2004, 04:56 PM   #5 (permalink)
SRToc Member
thunder6g's Avatar
Member Number: 12672
Trader Rating: (60)
and he's asking about installing an EGT gauge probe
If it's not a wideband type and just and a/f gauge not a meter reading on it then it'll be fine after the urbo on the hottest manifold pipe is what I have been told-
I assume it's not like a PLX or the other sensors that have 02 sensors that you just replace the second one with this new one for the gauge and xip strip the stock piece out of the way.
Did you try search for egt probe, or in the how to section?
thunder6g is offline   Reply With Quote
Old 12-06-2004, 05:02 PM   #6 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
I just finished a How-To, you can find it HERE
Old 12-06-2004, 05:16 PM   #7 (permalink)
cali's Avatar
Member Number: 159
6-7 inchas after the turbine
someone is watching me
Old 12-07-2004, 02:18 AM   #8 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (49)
thnaks pit viper. that will come in handy
Page generated in 0.20577 seconds with 13 queries
