Old 03-18-2007, 04:32 AM   #1 (permalink)
crackaddict's Avatar
Member Number: 24166
Default Where does DTEC pull boost #'s from?
so... where does a DTEC BC pull the boost numbers from? can i trust the numbers there more than the mechanical gauge?
i only ask this because i just installed an autometer boost gauge... to find out that the stock one was reading 7 pounds higher...
on the stock one, i showed boosting 21... but on the new autometer, max i boosted was 14.... w t f.
which do i believe?
crackaddict is offline   Reply With Quote
Old 03-18-2007, 09:09 PM   #2 (permalink)
Sensei's Avatar
Member Number: 17163
which do i believe?
My stock gauge was reading much higher also. Anyway, the Dtec BC has it's own boost sensor. You can plumb it in anywhere after the TB. Make sure you set up the calibration in the software. There should be a tag attached to the boost sensor that has the calibration numbers on it and the tech who checked it at turboXS.
Craig
Honda Tuning - 6-04 - pg 44-52 CRX
Mod Mag - 6-06 - pg 212 Time Attack
Import Tuner - 10-06 - pg 76-86 STI
Mod Mustangs - 11-06 pg 74-77 BDX
Mod Mag - 3-07 - pg 88-95 - SRT4
Mod Mustangs - Mar-Apr-May 07 - "Tire Testing"
AGP Turbochargers, Inc.
Clutch Masters
Drive Shaft Shop
RC Eng
Bondurant Instructor - 95-96
BDX Instructor - Current
www.craigdabbs.com
Sensei is offline   Reply With Quote
Old 03-18-2007, 09:56 PM   #3 (permalink)
no perhaps you misunderstood...
my dtec is already hooked up and configured, but i was wondering where it got the actual #s from... which you've also explained (thanks)... i didnt install it so i wasnt sure~
Old 03-19-2007, 12:18 PM   #4 (permalink)
Sensei's Avatar
Oh, got ya. my bad... Hmmm, can you get the calibration slip that came with it to make sure the Dtec is acurate? If so, then I would trust the Dtec and not the gauge.
Hope that helps.
Craig
Page generated in 0.15861 seconds with 13 queries
