Old 10-11-2006, 07:12 PM   #1 (permalink)
Pyrox's Avatar
Member Number: 28949
Default when is too much timing a problem
like the title says .... how much can you run .. or better yet how much should you expect with 750ccs reason i ask is because with the 750cc and return line you have to have the pressure pretty low at idle and you have to pull alot of fuel with your piggyback... and when you pull fuel you increase timing.... so i guess how much is too much
agp gt40
with some supporting stuff
stock exhaust no cat
277 hp 263tq @ 15 psi untuned
Pyrox is offline   Reply With Quote
Old 10-12-2006, 12:20 AM   #2 (permalink)
Member Number: 19287
when it starts knocking
S2 no toys+devilsOWN +AGP 50trim
294whp no tune
boosty is offline   Reply With Quote
Old 10-12-2006, 12:22 AM   #3 (permalink)
Member Number: 2096
When your motor blows up
xmdfmk7x is offline   Reply With Quote
Old 10-12-2006, 06:56 AM   #4 (permalink)
Member Number: 319
http://www.fs.isy.liu.se/~larer/Projects/main.html
Read this to understand the relationship between spark advance and how it affects cylinder pressure (the main goal of an internal combustion engine).
Page generated in 0.14926 seconds with 13 queries
