Old 07-26-2006, 04:28 PM   #1 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Default Whats wrong w/my dyno?
I went and dyno'd my car and made a best of 248 horses and 314ft lbs. I was hoping for a lot closer to 300 horses and am looking for some insight into how I made so much torque compared to the HP. The guy at the dyno said it was just a free spin dyno and he didn't put a load on it which would have helped my numbers. I've never dyno'd before so I don't know what to think about that. It was a DynoJet and my mods are AGP WGA 21/16, AGP Fuel Return, QW FMIC, Maxxfab SEE and 3" O2 housing, NGK 4306s, MSD Wires, AEM Intake, PTP Check Valve, JMB Hard Pipes, 1st GEN DSM BOV, Map Clamp @ 4.15volts, UEGO, and that's about it performance wise. Here's a picture of the graph. He said it was fairly smooth. Anything you guys can tell me about how to get my power up? Is it true the car will dyno more with a load on the dyno wheel?
http://i108.photobucket.com/albums/n...y/P7250069.jpg
HCCAFan is offline   Reply With Quote
Old 07-26-2006, 04:32 PM   #2 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
Here's a better picture of the dyno print out.
http://i108.photobucket.com/albums/n...y/P7270074.jpg
Old 07-26-2006, 04:34 PM   #3 (permalink)
BMF_RACING's Avatar
Member Number: 35730
Trader Rating: (12)
Thumbs up
the dynojet dynos always show about 10% to 15% higher hp #'s than the dynos that load the wheels ---> like a mustang dyno.
those numbers are a little low for dynojet. check for a boost leak. what are you holding psi at 6000rpm. less than 15 psi and its most likely a leak.
hope that helps,
1982 CUTLASS, 406 SBC 2-STAGE NOS 4255LBS -- BEST ET/MPH 11.02 @ 127.65 ON DOT'S AND 200HP N2o. NO CAGE, 7 COLORED SLEEPER 8 COLORS WITH THE RUST.
2004 SRT-4 S2 w/toys, 21/15.5agp wga, cca fmic, 3" cti o2, 3" mf dp no-cat , borla, cti pipes, 3" jmb cai, aem ebc, dtec fc 287hp/365tq
"there's two dates on your tombstone and all your friends will see 'em,
but the only thing that matters is that little line between 'em"
BMF_RACING is offline   Reply With Quote
Old 07-26-2006, 04:43 PM   #4 (permalink)
vegasDSM's Avatar
Member Number: 726
boost leak.....
and high ait's....
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 07-26-2006, 04:43 PM   #5 (permalink)
vegasDSM's Avatar
Member Number: 726
boost leak.....
and high ait's....
Old 07-26-2006, 04:46 PM   #6 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
He said he was able to apply a load to the dyno which would have made him input stuff like vehicle weight and speed and what not but for whatever reason he did not do it. We leak tested it prior to going to the dyno and found nothing obvious. It would have to be a very small leak and it still holds 16 to redline.
The high AITs were making the computer not give it much timing advancement you think?
Old 07-26-2006, 04:54 PM   #7 (permalink)
Member Number: 24364
High IAT's and possible detonation at boost spike causing a reduction in timing.
Check the obvious stuff first, then get something to monitor your knock retard and timing.
TJ
PS. I can't view the graphs from work, so Im just basing this off what everyone else is saying.
In Memory of Steven "Nightshade" Lorenz
May you rest in peace.
6/11/1987-4/4/2006
TJ1376 is offline   Reply With Quote
Old 07-26-2006, 08:14 PM   #8 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
I'm no expert but in the graph it did not look like it was heading up and then dropping sharply as I figure it would if the car was pulling timing. The guy at the shop also said it did not look like timing was being pulled. The boost leak tester I used does not have a gauge on it to watch and see how long the pressure stays in the system so that may be the next step. Kinda sucks that IAT could keep me from making power with all that is out there to help with knock ie. methanol and high octane.
Page generated in 0.20219 seconds with 13 queries
