Quote: Originally Posted by
MotsoSRT-4
So i go to the shop all i got is exhaust intake and ajustable wastegate, he tell sme i need a SAFC before i get it tuned, what is a good SAFC? looking around and i see mainly only apexi SAFC's. are there ather better brands? thanks for the help guys/gals.
If you're looking for just fuel removal for tuning (which is acceptable on most moderate builds), the SAFCII or SAFC NEO will suit you well. The latter provides more RPM ranges to correct fuel from, but both will get you in a good A/F ratio when tuned properly. It took me a good hour to get mine dialed in perfectly in 4th gear.
I see no reason for you to spend the money for an EMS with your mod list and the minimal amount of tuning you'll need to get your car running optimally. When you hit bigger turbos, port work and the like, then worry about a standalone system like the EMS.
