Old 09-30-2005, 04:06 PM   #1 (permalink)
Member Number: 3575
Default what voltage value = what O2 value
my logger is gonna log A/F by voltage, does anyone know on the stock O2 sensor what the voltage to O2 conversion is.
blue04 is offline   Reply With Quote
Old 10-03-2005, 08:31 PM   #2 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (24)
I was wondering the same thing! The DRB at my dealership reads o2 voltage but not a/f ratio.
04 S3 11.89@115 Untuned
Old 10-03-2005, 10:14 PM   #3 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
dont tune off of a stock 02 sensor, or any narrowband o2 sensor. get a wideband if you want to be able to properly tune your car or know if your rich or lean.
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 10-04-2005, 06:55 AM   #4 (permalink)
Member Number: 3575
i appreciate your input, but, if the ecu can run its algorithims basaed off of that stock sensor, it has some value, im not looking for hardcore tuning, i just wanna know if i am going to hurt something, as i said my laptop logger logs volts not value
Old 10-04-2005, 08:57 AM   #5 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
The voltage range for the SRT 02 sensor is 2.5 to 3.5. I was not able to make any sense of it as it doesn't compare to a 0-1volt system on most other cars.
Good Luck.
Marion
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 10-04-2005, 11:06 AM   #6 (permalink)
'03r/t4me's Avatar
Member Number: 18911
the o2 sensor still responds in a 0-1 volt pattern, NGC bias the ground @ 2.5 volts for diag purposes. if u know the 0-1 pattern, just add 2.5 to it.
I believe 0 = lean & 1 = rich.
'03r/t4me is offline   Reply With Quote
Old 10-05-2005, 07:30 AM   #7 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Well if you want some 0-1v associations with afr here is what I used to do and many older TD guys use.
.99-97v = pig rich and slowing you down
.96-93v = safe
.93-90v = perfect on 93 octane
.90-.87v= race gas/alky time
Here is a video of my dyno pull from last year with a Mopar Perf 0-1v 02 sensor hooked up to a gage I made.
http://thedarkroom.us/jason_pics/marion_dyno/vid4.mov
It's showing .96 volts at very hi boost but if you look you will see the little green light, that means I'm spraying alky too so that richens the afr some.
Hope this helps.
Marion
Old 10-05-2005, 08:39 PM   #8 (permalink)
Trader Rating: (24)
.96-93v = safe
So running 94+ octane is should shoot for .90 volts? Just making sure thanks for the breakdown. I'm going to use the DRB where i work and try tuning it in probably on sat. at our local airport flashlight drags
Old 10-05-2005, 09:20 PM   #9 (permalink)
Member Number: 26656
Trader Rating: (20)
Red face
i have a pocket logger and i was only running 13 pounds and my volts were at .89v to about .93v is that lean rich or good i am on 91 octane
Bills is offline   Reply With Quote
Old 10-06-2005, 07:23 AM   #10 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
That would depend when you were at .89 v and at .93v in the rpm range. My "guess" is that at 13 psi you are ok. If the leanness is early in the rpm range then things are most likely ok.
Marion
Old 10-06-2005, 12:12 PM   #11 (permalink)
dsmlights's Avatar
Member Number: 1186
Trader Rating: (13)
best way to figure it out guys is to get wideband and the dataloger and find out
well ill order dataloger this week and let u guys know "
--------Dyno#s update 4/01/05--------
stock turbo spike 21 psi and drop to 15 to red line
307 whp/370 wtq
-----------Dont remerber the date --------------
last dyno i will spray on stock turbo
410 whp/435 wtq Now its running harder
---------------Bigger turbo in 24psi--------------
ran like a champ for 2 days then the motor messed up, now debating wa to get any suggestions
not bad for S0 car right :0
dsmlights is offline   Reply With Quote
Old 10-06-2005, 02:46 PM   #12 (permalink)
Member Number: 5851
From what I could tell on my car these are some of my observations. I think stoich is around .650 volts, rich on my stage 2 seems to be .920 to .940, and it starts running lean around .880 and lower. I can't relate the volts to any specific air fuel number but you can extrapolate it a bit. Most people say our cars run around 10:1 at the rich end which would be .940 on my car, and stoich is around 14:1 which appears to be .650 volts. If anyone has some direct info I'd love to see it too, understanding that narrow bands aren't as accurate.
EBP 04 SRT-4.
JSRT4 is offline   Reply With Quote
Old 07-04-2006, 10:53 AM   #13 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (42)
bump for a good thread.
anyone have any more input?
BTR is offline   Reply With Quote
Old 07-05-2006, 02:35 PM   #14 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
It's funny how people are going to make tuning decisions that could have devistation effects based on bias information . . .
Get a wideband.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 07-06-2006, 01:53 PM   #15 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Get a wideband.
It's old school but not necessarily funny nor biased. WB's are realtively new to personal owners and particualrly in a car as a standalone. So you use what is there. I've had 02 meter in cars for years and if you do not try to set a "point" but a range you are ok. Thats why so many TD users have EGT gages.
FYI,
Marion
