Old 12-26-2004, 07:57 PM   #1 (permalink)
wfosrt's Avatar
Member Number: 2499
Default What a/f ratio to tune for with S2+big turbo???
It seems that people with big turbos are running about a 12:1 AFR. Is that to lean for pump gas??? I will have a 3147 turbo, boost controller,wide band o2 and S2. With this setup the afr will start to lean out up top right (when the boost level starts to get to high )?
03' BLACK AGP 3147 Turbo kit. AGP 750cc fuel kit, AGP Spark Plugs
(14.5psi)297WHP/289WTQ
RIP: 6/5/05
94' EJ1 (d16z6 turbo)
wfosrt is offline   Reply With Quote
Old 12-26-2004, 08:02 PM   #2 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
Honestly, for safetys sake, I'd stay 11.5:1 up top. I'd rather be a few horsepower shy of max and have a motor that lasts then try and squeeze every last bit out of it. You also need to be watching your egt's and have something hooked up reading the knock sensor
Glacius is offline   Reply With Quote
Old 12-26-2004, 08:13 PM   #3 (permalink)
wfosrt's Avatar
Member Number: 2499
Yeah. I plan on getting an egt probe drilled into the manifold. Where can I get a knock guage.
Old 12-26-2004, 08:15 PM   #4 (permalink)
wfosrt's Avatar
Member Number: 2499
Another question. Is it ok to be lean in the lower midrange? In all the dynos that I see the car is ~13 afr untill about 3-3750 rpms.
Old 12-26-2004, 10:35 PM   #5 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
you can go a bit leaner down low because you're not making as much boost, but the majority of the times it's showing that 13+ afr cuz they're only partial throttle, hitting the activator on the dyno and then going full throttle. basically, if you're full throttle, you want to be no more then 12.0:1 imho. Do 12.0:1 until about 3700 and then from there u want to bring it down to 11.5:1 for a safe and happy motor
Old 12-27-2004, 02:56 PM   #6 (permalink)
Member Number: 13849
I'd say look at both EGTs and AFRs as long as the reading within limits and there is no knock I'd say it is tuned
NoLongerStock is offline   Reply With Quote
Old 12-27-2004, 03:44 PM   #7 (permalink)
PVO SRT's Avatar
Member Number: 4949
I have mine set up for 11.4-11.6 and i'm into the 470 range. I'd rather be safe and a bit low on hp.
04 SRT-4, Mopar STS, 3" Flowmaster exhaust
*SOLD*
Canadian Nationals, Sep 23-25. TMP.
Thanks for a great event..
Canadian Nationals, Sep 15-16...
2006 SRT-8 Grand Cherokee.
PVO SRT is offline   Reply With Quote
Old 12-28-2004, 02:27 PM   #8 (permalink)
Orange Blast OC's Avatar
Member Number: 21478
Trader Rating: (32)
I agree....that's where I have my Focus tuned. It's better to be safe than sorry.
'05 SRT-4 BACK TO STOCK!!
Orange Blast OC is offline   Reply With Quote
Old 12-28-2004, 02:32 PM   #9 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
11.8:1 or below. no lower than 10.8:1
Page generated in 0.20891 seconds with 13 queries
