Old 09-19-2007, 07:19 PM   #1 (permalink)
Straight Boostinn's Avatar
Member Number: 53071
Default what code is this and how do i fix?
P2074-manifold Pressure/throttle Position Correlation
- High Flow/vacuum Leak
Straight Boostinn is offline   Reply With Quote
Old 09-19-2007, 07:26 PM   #2 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (28)
Ummm did you check for vaccum leaks by your manifold?
stxsrt is offline   Reply With Quote
Old 09-19-2007, 09:03 PM   #3 (permalink)
Spunjah413's Avatar
Member Number: 41050
Code comes from prolonged PTB. Stage 0 i assume? Just dont hit PTB for too long and it wont throw. Also reset your PCM, that code puts your car in Limp mode
Spunjah413 is offline   Reply With Quote
Old 09-20-2007, 06:17 AM   #4 (permalink)
stxsrt's Avatar
Trader Rating: (28)
I stand corrected. Learn something new everyday. PTB sucks glad I dont have it
Old 09-25-2007, 05:27 PM   #5 (permalink)
letsrunem8's Avatar
Member Number: 57330
[quote=stxsrt]
so wait what is ptb??
and wat does it mean by putting your car in limp mode???
cuz i got the same exact problem its throwing that code
letsrunem8 is offline   Reply With Quote
Old 09-25-2007, 06:02 PM   #6 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
part throttle boost. when you're not WOT and you're getting a lot of boost it's bad for the car cuz it's way too much air and not enough fuel. P2074 is commonly referred to as the overboost code, and that would be why. Limp mode basically takes away all your power and I don't even think it'll let'cha go above 4Krpms until you unplug the battery and reset the code
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 09-25-2007, 06:17 PM   #7 (permalink)
letsrunem8's Avatar
ohh okayy...so how do i reset the code?
lol sorry
newbie
Old 09-25-2007, 09:05 PM   #8 (permalink)
Spunjah413's Avatar
Unplug your battery for a short time, then reinstall. Or go to autozone and use their OBDII reader to erase the code.
Just don't try flooring it or even going half throttle unless @ 3k RPM with an aftermarket wastegate.
Old 09-25-2007, 09:09 PM   #9 (permalink)
letsrunem8's Avatar
thankkkss....but i have the OBDII reader...but if im not mistaken i have to get a wastegate now in order to floor it?
Old 09-25-2007, 09:16 PM   #10 (permalink)
No the above poster was stating the fact that with an aftermarket wastegate on the car if you give it too much boost under 3K rpms that code likes to pop up. I'm sure you most likely don't need a new wastegate, the stock one is most likely just fine
Old 09-25-2007, 09:21 PM   #11 (permalink)
Spunjah413's Avatar
No, Only if you want more POWAAAA
Old 09-25-2007, 10:24 PM   #12 (permalink)
letsrunem8's Avatar
hahaha okayy thats good..
but so how do i fix the cel that my sensor said to be p2074?
tip mod?
Old 09-26-2007, 02:56 AM   #13 (permalink)
TIP mod will most certainly do the trick for ya
Old 09-26-2007, 09:12 AM   #14 (permalink)
letsrunem8's Avatar
thanks alot bro...i appreciate it
Old 09-26-2007, 01:22 PM   #15 (permalink)
California Moderator
Mana4real's Avatar
Member Number: 25021
Depends on what year car you have... 05's it doesn't always work...
-Matt- -SCT Tuned- By Yours Truely
05 SRT-4 Stage 3 47lb FP Green
