Old 07-18-2006, 09:34 AM   #1 (permalink)
Nasty_NAS's Avatar
Member Number: 11197
Default weird afr's in close loop
can some one give me some idea's what could be casuing it.. when crusing around out of boost the afr's are all over the place. I have checked the plugs replaces the up stream o2 sensor. my wideband is in the downstream location spot on the injen downpipe, which is like the shape of a "Y" could that be it?? what could be going on?? cause when you get into boost they seems good.. please help
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
Nasty_NAS is offline   Reply With Quote
Old 07-18-2006, 09:37 AM   #2 (permalink)
Member Number: 14585
Trader Rating: (19)
Yeah they will jump around only watch about afr's at wot and idle
bigdoggsrt4 is offline   Reply With Quote
Old 07-18-2006, 11:17 AM   #3 (permalink)
Nasty_NAS's Avatar
well yeah but I was pretty sure it should move that much
Old 07-18-2006, 11:19 AM   #4 (permalink)
HLFVIPR's Avatar
Member Number: 25322
Trader Rating: (13)
Are you still on Stage 0 stock computer??? If so the PCM still needs the downstream O2 sensor, I just ran into the same probs that you have and I replaced my downstream and the problem is non-existant now
HLFVIPR is offline   Reply With Quote
Old 07-18-2006, 02:08 PM   #5 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
anthony,
He has Stg1 and a DBB 50 trim, return line w/38 psi of fuel, 750's, W/Inj and a DTEC. The car will idle from the mid 13's to the upper 14's but not really cleanly. But when he gives it throttle the afrs start to richen and once in a while go lean for a sec. They go in the 11's? BTW the stock downstream 02 is still plugged in to the ecu but not in the exhaust.
During WOT it is all good. Or so it seems. It's currently tune to mid 11's in the midrange down to 11.2 @ redline.
Nasty's Injen DP has a 1.5" diameter tube off of the DP near the flex section that the 5-6"s long and runs "towards" the front of the car. It forms a Y pipe looking arrangement. The WB sensor is set in there. To me it seems to be out of the natural flow of the exhaust and may be the culprit.
It's either that or the ecu struggling mightily to go "stoich". He has plenty of low load correction in the 25/50/75 columns. In the 20's to high teens. Maybe it needs more?
I put in my LM-1 and it did not change the results. I guess the next thing is to either use a scantool and check FT's or move the WB location.
Anyone with any thoughts?
FYI,
Marion
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 07-18-2006, 02:24 PM   #6 (permalink)
Member Number: 26275
Generally in Closed Loop the PCM wants to keep a 14.0-15.2 AFR...If he's showing 13s-low 14's maybe the PCM is having problems pulling all that fuel to keep the "stock" fuel trim
2004 E-BLUE SRT-4
Precious Few are Born With It...Even Fewer Know What to Do With It
EssArTee-4 is offline   Reply With Quote
Old 07-18-2006, 02:38 PM   #7 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
If it was only at idle those would be good numbers, it's when the accelerator is pushed it richens up to the 11's like an accelerator pump on a carburator.
Marion
Old 07-18-2006, 02:50 PM   #8 (permalink)
Member Number: 11681
Trader Rating: (96)
Marion
Did this just start happening or was something changed or installed recently?
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
Old 07-18-2006, 02:53 PM   #9 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Marion
dan,
AFAIK he has had this problem for quite a while. I believe that his last install was the Coolingmist Supa Dupa Controller kit.
Marion
Old 07-18-2006, 03:36 PM   #10 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
so your saying at TIP in on the gas or crusing? the car is going mid 11s a/f
is it at any given RPM or just constant?
Vector is offline   Reply With Quote
Old 07-18-2006, 03:41 PM   #11 (permalink)
Trader Rating: (96)
Marion
dan,
Marion
Does his w/i come on via boost switch or via TPS voltage. Not firmiler with the controler but a shot in the dark cause you mentione when he hits the gas even at idle it goes rich just a guess if its run off TPS could it activate the system??? I think some controlers use the MAP never heard of using the TPS.
Old 07-18-2006, 03:59 PM   #12 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Marion
dan,
Marion
It's boost regulated but not for certain if it is pressure or map voltage. Nevertheless we had the box unplugged when we baselined the fuel and boost and it was whacky. Only after it was where we wanted it did we add the w/inj.
Marion
Old 07-18-2006, 04:20 PM   #13 (permalink)
HLFVIPR's Avatar
Trader Rating: (13)
I think that the wideband needs moved "into" the exhaust stream. AEM recommends 24-36"'s away from the turbo in the exhaust stream.
Old 07-18-2006, 04:26 PM   #14 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (401)
HAHAH. You guys are silly. The wideband needs to be put back into a normal spot. Thats to keep the stock o2 from tossing a code with no cat.
10.62@133.8 '05 SRT-4 Neon
11.62@128 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 07-18-2006, 04:31 PM   #15 (permalink)
acancelledczech's Avatar
Member Number: 35576
Marion
I'm really confused...a 1.5" diameter downpipe??? Is this some sort of open wastegate? and the wideband is in that?
Sony A700 ~ SRT-less
acancelledczech is offline   Reply With Quote
