Old 05-17-2009, 07:20 PM   #1 (permalink)
05redSrtfour's Avatar
Member Number: 54938
Trader Rating: (26)
Default wanting to run 22 psi
hey im doing a rebuild on my motor and was thinkin about boring it out, with some stage 3 cams, and wanting to run 22 psi, could i adjust the boost i wanted to 22psi on the stock turbo with some 750's? and other fuel supporting mods? or how do i get around pcm control?
12.66 @ 109 1.80 60ft
Stage 1, JMB Ultimate CAI, B&B 3"TBE, AGP Hardpipes w/Hks BOV, AGP upgraded WGA,. 62mm TB. Ported Intake Manifold., MSD Coil Pac,. MPx FMIC,. Ported Stock Turbo., FBM Ported/ Ceramic Exhaust Manifold, Maxxfab 3" 02 Housing., AEM Truboost., 180T-stat., Hondata IM gasket,. AEM wideband, 24.5x8.5 M&H Slicks, AGP motor and tranny mounts,. Tein S-techs. not installed: Coolingmist Direct Port meth inj
05redSrtfour is offline   Reply With Quote
Old 05-17-2009, 07:43 PM   #2 (permalink)
ziggo0's Avatar
Member Number: 63759
750's any way are to much for a stock turbo...if you plan on running e85 & FRL that would be ok, if not don't do it.
Flame Red 2004 SRT-4 - Sold for a car that I can afford, a DSM ROFL.
Old 05-17-2009, 07:54 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (20)
sounds like your doing some engine mods, when you start opening up the head and adding a large cam your motor will need more flow on a stock motor 18-20 psi @ red line would be max, with some cams and head work i would put that at about 16-17 psi max with a stock turbo (your gonna need a bigger turbo) now your fuel ....some 750's and a 255 pump (a clamp or safc) should do fine with some to spare, when you upgrade the tiny stock snail you will be good to go
about your stage 3 cam selection: what you will need to know is your cam's duration and overlap will need to be paired with the correct turbo (due to back pressure) a large cam will make you lose power with a small turbo ...something a little more conservative would be better and give ya better performance
Old 05-17-2009, 10:36 PM   #4 (permalink)
Trader Rating: (26)
whats your idea of something more conservative? say i have $2500 what should i do? brian crower stage 3 cams would slow me down if i didnt upgrade the turbo?
